Error: Unsupported speed-feed synchronization activation command. Error in operation: 'Thread1'
sgZVHZM
sgZVHZM
Hello. I need help with the post processor after fusion updates I cant post process Thread operation.
Before updates it was working just fine.
serge.quiblier
Hi @sgZVHZM
I quickly tested your post, and it seems to work OK.
Are you sure you have check the box here :
Regards
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
sgZVHZM
Hi. I checked this box, unchecked it. No difference. I tried to change every single property and nothing.
The same error again and again.
serge.quiblier
Using your post, on an existing Fusion file.
The cycle is checked in the operation and we tweak on post property:
Case 1 :
Case 2:
I am running the latest version of Fusion.
The problem occurs on a new file? Can you test with a file created before the update?
Regards.
Serge.Q
cam.autodesk.com
sgZVHZM
Seems like you was right. I messed up with the properties after update. I checked the cycles box in operation but didnt check in post configuration. It works just fine now.
Sorry for the confusion. And thank you for your help!
