Error machine okuma turning thread programs with G32
best25AX5
best25AX5
My machine can read only g33 for now i customize post processor change g32 to g33
the machine error because when i post the program example : (N24 G33 Z-19.6 F1. ) the post process will post only z axis but my machine can read with x axis and z axis together
How to customize post processor to make x and z axis together in 1 line
(1001.MIN)
N10 G50 S6000
N11 G0 X400.
N12 G0 Z400.
(THREAD1)
N13 T010101
N14 G90 G95 G18
N15 M8
N16 G97 S500 M3 M41
N17 G0 X45. Z5.
N18 G0 X7.466
N19 G33 Z-19.8 F1.
N20 X7.866 Z-20. F1.
N21 G0 X45.
N22 Z5.
N23 X7.066
N24 G33 Z-19.6 F1.
N25 X7.866 Z-20. F1.
N26 G0 X45.
N27 Z5.
N28 X6.666
N29 G33 Z-19.4 F1.
N30 X7.866 Z-20. F1.
N31 G0 X45.
N32 Z5.
N33 X6.266
N34 G33 Z-19.2 F1.
N35 X7.866 Z-20. F1.
N36 G0 X45.
N37 Z5.
N38 X5.866
N39 G33 Z-19. F1.
N40 X7.866 Z-20. F1.
N41 G0 X45.
N42 Z5.
N43 M9
N44 G0 X400.
N45 G0 Z400.
N46 M2
andrea.amilo
Hello @best25AX5 ,
I'm sorry but I am not able to find the modification you made to the attached file, which seems to me to be the same as the original okuma turning post.
So I suggest you how to always write X and Z in turning threads in the original Okuma turning post.
Try adding the highlighted line:
I hope this could help you.
Please test it carefully and let me know.
Andrea Amilo
Senior Technical Consultant
Autodesk Knowledge Network | Fusion 360 Webinars | Autodesk Make
best25AX5
Thank for your answer
This is format can work with my machine
(THREAD1 4)
N300 M1
N301 T040404
N302 G90 G95 G18
N303 M8
N304 G97 S500 M3 M42
N305 G0 X45. Z5.
N306 G0 Z2.0
N307 X19.97
N308 G33 X19.97 Z-41. F2.5
X19.94
X19.91
X19.88
X19.85
X19.82
X19.79
X19.76
X19.73
X19.7
X19.67
X19.64
X19.61
X19.58
X19.55
X19.52
X19.49
X19.46
X19.43
X19.4
X19.37
X19.34
X19.31
X19.28
X19.25
X19.22
X19.19
X19.16
X19.13
X19.1
X19.07
X19.04
X19.01
X18.98
X18.95
X18.92
X18.89
X18.86
X18.83
X18.8
X18.77
X18.74
X18.71
X18.68
X18.65
X18.62
X18.59
X18.56
X18.53
X18.5
X18.47
X18.44
X18.41
X18.38
X18.35
X18.32
X18.29
X18.26
X18.23
X18.2
X18.17
X18.14
X18.11
X18.05
X18.02
X17.99
X17.96
X17.93
X17.9
X17.87
X17.84
X17.81
X17.78
X17.75
X17.72
X17.69
X17.66
X17.63
X17.6
X17.57
X17.54
X17.51
X17.48
X17.45
X17.42
X17.39
X17.36
X17.33
X17.3
X17.27
X17.24
X17.21
X17.18
X17.15
X17.12
X17.09
X17.06
X17.03
X17.
X16.92
X16.95
X16.90
X16.87
X16.84
Z16.80
X16.77
X16.74
Z16.70
X16.67
X16.64
Z16.60
N740 M9
N741 G0 X400.
N742 G0 Z400.
N743 M30
andrea.amilo
Hello @best25AX5 ,
I'm sorry but I don't understand if what I suggested is helpful for your topic.
Please let me know if you need any clarification.
Thanks.
Andrea Amilo
