Error: latin changed
Good evening everyone!
I'm getting the following error in Autodesk Inventor 2017 with HSM.
Read some other topics which say it's a fault in the dimensions, but even with the simplest sketch it won't work!
Information: Configuration: Siemens SINUMERIK 840D
Information: Vendor: Siemens
Information: Posting intermediate data to 'C:\Users\Koen Smulders\Downloads\1001.mpf'
Error: Failed to post process. See below for details.
Code page changed to '1252 (ANSI - Latin I)'
Start time: Tuesday, January 3, 2017 9:20:25 PM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.2.1 40830
Configuration path: C:\Users\Public\Documents\Autodesk\Inventor HSM\Posts\siemens-840d.cps
Include paths: C:\Users\Public\Documents\Autodesk\Inventor HSM\Posts
Configuration modification date: Friday, April 15, 2016 8:25:12 AM
Output path: C:\Users\Koen Smulders\Downloads\1001.mpf
Checksum of intermediate NC data: 0e20cb16906821a74a7febbaba406a57
Checksum of configuration: 36fe9d8af52c6b5890be86f65bd506f8
Vendor url: http://www.siemens.com
Legal: Copyright (C) 2012-2015 by Autodesk, Inc.
Post processor signature could not be verified (error 0xfffffffc).
Generated by: Inventor HSM Pro 4.0.0.032
Error: Turning toolpath is not supported by the post configuration.
Error: Failed to invoke 'onOpen' in the post configuration.
Error:
Error: Failed to execute configuration.
Stop time: Tuesday, January 3, 2017 9:20:25 PM
Post processing failed.
It would be grate if someone can help me!
Kind regards,
Koen
ksmulders
 It looks like you are trying to post turning tool path on a milling post.  The post you are using is telling you that turning tool path is not supported.
Can you explain more about the file and post you are using?  we will try to provide better guidance on what posts to use or what can be done to fix your issue.
Hi!
Thanks for the fast reply, I appreciate that!
In the attachment you can download my .IPT file.
In the setup it's configured as turning, not milling.
Maybe when one of you takes a look it will be clear.
Laurens-3DTechDraw
@Anonymous wrote:
Hi!
@Anonymous is right. You are using a milling post processor for turning operations.
You can find the turning Siemens post here: http://cam.autodesk.com/posts/?p=siemens_turning
And the Mill-turn version here: http://cam.autodesk.com/posts/?p=siemens_mill-turn
I see you have a lot of manual NC operations in there. They might not be supported by the post processors out of the box but we can make the support if they don't work.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Great! This worked for me, had some difficulties finding the webpage you gave me!
Do you know how to program the Manual NC's? Because it would be amazing if they worked.
Hi Everyone,
I have the same problem here, even using a turning post:
Information: Configuration: FANUC Turning
Information: Vendor: Fanuc
Information: Posting intermediate data to 'C:\Users\VA-MFG950\Desktop\Clientes\TMSA\1004.nc'
Information: Total number of warnings: 1
Code page changed to '1252 (ANSI - Latino I)'
Start time: Friday, August 24, 2018 2:35:49 PM
Code page changed to '20127 (EUA-ASCII)'
Post processor engine: 4.2.1 42050
Configuration path: C:\Users\Public\Documents\Autodesk\Inventor HSM\Posts\FANUC - TMSA.cps
Configuration modification date: Friday, August 24, 2018 2:33:40 PM
Output path: C:\Users\VA-MFG950\Desktop\Clientes\TMSA\1004.nc
Checksum of intermediate NC data: 029dbb4bc4c4af0ba6cab1fa5ad98991
Checksum of configuration: 208e14b5faf786240fa603d53cb5cf95
Vendor url: http://www.fanuc.com
Legal: Copyright (C) 2012-2018 by Autodesk, Inc.
Generated by: Inventor HSM Ultimate 6.2.1.15639
Warning: Work offset has not been specified. Using G54 as WCS.
Error: Unsupported 'air' coolant.
Error in operation: 'Profile1'
Failed while processing onSection() for record 752.
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Stop time: Friday, August 24, 2018 2:35:49 PM
The only thing i made diferent is using "Air Coolant", i have see a link below but the file post is diferent and i never find the line that is mentioned editing the post:
https://forums.autodesk.com/t5/hsm-post-processor-forum/post-processor-coolant-here-is-how-to-suppor...
Best Regards
Jorge Andrade
