Error in Post processing to turning
domingosf
domingosf
Hello.
I'm using Inventor 2022 and CAM 2022 and some errors happen when I try to configure Post processing for fanuc turning.cps in Setup>Edit>Machine Configuration. See the figure below.
Note that in machining I do not use the Y axis.
In Setup > Select it is set to Generic Lathe.
As I cannot configure the post processor in Setup, I cancel and access the Post Process option in ribbon, but an NC program is not generated and this error is displayed:
Information: Configuration: FANUC Turning
Information: Vendor: Fanuc
Information: Posting intermediate data to 'F:\AULA\CAM\LIVROS\INVENTOR CAM\2805.nc'
Error: Failed to post process. See below for details.
Code page changed to '1252 (ANSI - Latino I)'
Start time: Thursday, May 26, 2022 6:05:59 PM
Code page changed to '20127 (EUA-ASCII)'
Post processor engine: 4.5748.0
Configuration path: C:\Users\Public\Documents\Autodesk\Inventor CAM\Posts\fanuc turning.cps
Include paths: C:\Users\Public\Documents\Autodesk\Inventor CAM\Posts
Configuration modification date: Thursday, May 26, 2022 3:53:38 AM
Output path: F:\AULA\CAM\LIVROS\INVENTOR CAM\2805.nc
Checksum of intermediate NC data: 12878a23f184cb7ea358e4a6f5c0a010
Checksum of configuration: 2ed50ddae8b83b3cfc53ba70ca6ef449
Vendor url: https://www.fanuc.com
Legal: Copyright (C) 2012-2022 by Autodesk, Inc.
Generated by: Inventor CAM Ultimate 9.0.0.24791
Error: Invalid machine configuration in toolpath.
Error: Failed to execute configuration.
Stop time: Thursday, May 26, 2022 6:05:59 PM
Post processing failed.
I updated the post processors and the error persists.
If in Setup> Select I change to Generic Mill-Turn Lathe and then configure the Post Processing in Edit>Machine Configuration for fanuc turning.cps, the error does not occur, however, when generating the NC program it is generated with a milling tool in Autodesk HSM. See the figure below.
And all tools configured for turning disappear.
Other post processors also fail. Tried Hass, Mazak and others.
I update both to 2023 version but the same occurs.
Is there any configuration that needs to be done so that these errors and failures do not occur?
Thank you very much for some help.
Domingos
bob.schultz
Hello Domingos,
This is an issue with Inventor.  It is not necessary to use a Machine Configuration with lathe post processors, actually the Machine Configuration is not used by any of our turning posts.  You can remove the Machine Configuration from the Setup and it should post without errors.
Bob Schultz
Sr. Post Processor Developer
domingosf
I left the configuration in "Post Process" as shown in the following figure and unchecked it in "Setup", but it didn't work. The error persists.
I have tried other configuration combinations, but the problem remains.
What can you suggest me?
bob.schultz
Thanks for providing your model, I have tried it here running the following versions of Inventor and Inventor CAM.
Autodesk Inventor Professional 2023
Build: 158, Release: 2023.0.1 -Date Wed 04/27/2022
Build: 10.0.0.21308
Post processor version: 4.5843.0
I selected a machine configuration and get the same error that you do, but after deselecting the machine configuration it runs without issues.  The Setup should look like this without the red X displayed.
If you are running the same versions that I am and are still having the problem, then please try creating a new Setup without a machine configuration and copying the operations into this Setup to see if this resolves the issue.
Bob Schultz
domingosf
With the update to version 2023 and rebuilding the setup without selecting the machine, it was possible to generate the G code successfully. I am gratefull for that.
Some other issues need attention:
The stock size defined in Inventor CAM does not persist in Autodesk HSM.
Tools configured in Inventor CAM do not persist in Autodesk HSM.
I don't know if any configuration is required to succeed with this.
bob.schultz
When you mention Autodesk HSM, which main product are you referring to, Inventor, HSMWorks (SolidWorks), or Fusion 360?
Bob Schultz
domingosf
To Inventor
