Emco Maier Compact 6p 120p lathe post processor including results
Welcome to my second post processor project.
The Machine:
Emco Maier Compact 6p sometimes called Compact 6 CNC P or Compact 120p
The controller is an old TM01, so beware if your machine has a more modern TM02
My lathe's controller software revision is:
AC03.02/DC03.05
Some basic facts about the machine:
Working area
- Swing over bed 180mm
- Swing over cross slide 75mm
- Max length between centers 180mm
- Max diameter of workpiece 90mm
Main spindle
- Through hole 21mm
- Speed Range 80 - 4000 rpm
- Manual chuck 80 / 85mm
- Pneumatic power Chuck (without through hole)
- Pneumatically operated tail stock
Automatic tool turret
- 4 external tool holders (12mm shank)
- 4 internal tool holders (16mm bore)
Main drive
- 2 kW DC motor
Feed motors
- Feed 1-1200 mm/min
- Resolution 0.001 mm
- Feed Power 2000 N
- Rapid traverse 1200 mm/min
As the new forum don't permit editing of posts (I think) the updates will be below newer posts. A useful status update should have a summary of:
What's been tested, the result, suggestions or questions on how to proceed and maybe a attached file of the success, disaster and or a new post processor file.
At the moment the postprocessor is in early development and can't be used.
What is working (afaik):
- Program header
- Formatting of code (NXXXX<space><space>G-code)
- Linear interpolations
What is missing or not working:
- Tool change, Need some type sequence here, maybe M00 then move to safe position, make tool change and force new G00 to entry position
- Ending of program move to safe position, reset offsets and turn off spindle
- Drilling cycle
- Threading cycle
- More cycles?
- Update the description in the post
