Edit post to change Z direction for Swiss
smurphyBTXGS
smurphyBTXGS
Im trying to find in the post where to set the direction for the Z axis. I've tried playing around with the machine configuration by changing the Z vector in the kinematics but it doesn't appear to change anything when I post the program.
We have swiss automatic lathes and the Z cuts in the positive direction. I don't mind having multiple posts based on what configuration I need for the machines. I've had a lot of success editing posts for Mastercam but I cant find the lines of code I need to change in the Fusion post.
The post I'm using is the DMG Mori NLX Mill/Turn
CNC_Lee
@smurphyBTXGS
If the generic DMG Mori NLX Mill/Turn post is not providing the required output, I offer post processor development services and happy to work out a solution for your machine! Please message me if further assistance is needed.
If my post answers your question, please use Accept as Solution.
CNC Lee
Autodesk CAM Post Processor Expert
purpc_cardoso
var xyzInvertedFormat = createFormat({decimals:(unit == MM ? 3 : 4), scale:-1});
Copy this line to your "Var" zone in your post processor.
var zOutput = createVariable({onchange:function () {retracted = false;}, prefix:"Z"}, xyzInvertedFormat);
on the line you see "var ZOutput" replace by xyzInvertedFormat
example:
All Z will be inverted, but you  also need to invert the K for g2/g3
var "kOutput = createOutputVariable({prefix:"K", control:CONTROL_FORCE}, xyzInvertedFormat);"
