- Mute
- Permalink
- Report
I have a post that is very close but need a couple of tweaks. Currently I am using the standard Doosan mill turn post with the machine configured to Y axis false. The machine is an older Daewoo Puma 230MS which does not have a Y axis. I am able to mill what I need using C axis polar interpolation thanks to Tom at Autodesk product support. I have two more things that need to be changed.
1. Move M90 to after M35. M90 is C axis unclamp and apparently it will only unclamp after the milling spindle stops (M35).
2. Remove G17. Not sure why but the machine gets hung up on it and it then runs fine if I remove it.
Here is a post before the edits and a post after I manually changed it to what I need. The cps file is also attached.
Thanks for any help.
