Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Does Fusion 360 support Cincinnati Milacron with A2100 siemens control
Message 1 of 12
Hi there,
i wanted to know if Fusion 360 support Cincinnati Milacron with A2100 siemens control. i have two lathes and mills and i wanted to make the switch and i wanted to know if it works with it.
Replies (11)
Message 2 of 12
Laurens-3DTechDraw
Fusion 360 has an "open" post processor. What I mean by that is that nearly anything is possible with the post processor and so nearly any machine can be controlled.
Not all machines or controls have a post processors made already but they can be made by yourself or you local re-seller.
Have a read here on how you could edit your post processor: https://camforum.autodesk.com/index.php?topic=8286.0
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
Message 3 of 12
I realize this post is a few months old, but I was curious if you found a post processor for the cincinnnati  2100 controls.   I have a Cincinnati Arrow 2100 machine and am curious if Fusion 360 will communicate with it.
Thank you for your time,
Jeff
Message 4 of 12
Hi Jeff,
No i wasn't able to find a post for those machines. i ended up liquidating the machines and buying newer Fanuc control machines which are much better.
I just stripped a falcon 200 and an arrow 750 if you need parts let me know.
Best of luck.
Message 5 of 12
Hi all
We have a Cincinatti Milacron Hawk 150 with the Siemens A2100 and have the same problems, because Fusion 360 not support it. So we will be happy if someone have the right post processor setup to.
Best Regards.
Message 6 of 12
BDROTARUM9RQX
I own a Sabre 750 with Acramatic 2100 control. I give up Camworks because i find easy to use Cam in Fusion360. After i learn enough i found that A2100 cannot use generated code. As they said. Is a general post. Too bad. I think now i have to step back.
Message 7 of 12
BDROTARUM9RQX
I tested and post is working. I'm sorry for previous post.
I think the problew was with G98. It has to be alone in the line.
After i edited post it worked like a charm. Thanks
Message 8 of 12
Which post did you use?
Message 9 of 12
BDROTARUM9RQX
acramatic.cps
Message 10 of 12
were you able to get G81 G82 g83 cycles right i will give it a try and see how it goes.
Thanks for the input.
Message 11 of 12
BDROTARUM9RQX
G81 and G83 codes was present in my program and i didn't received any error
Message 12 of 12
This post is for a Mill only not for the lathe.
