HSM Post Processor Forum
DMG DMU 50 Siemens 840D Post
9 REPLIES 9
Message 1 of 10
carlson_spencer
3717 Views, 9 Replies
I am looking for a DMU 50 post for the Siemens 840D controller and can't seem to find it. Anything helps!
9 REPLIES 9
Message 2 of 10
Arun.rs
in reply to: carlson_spencer
Hi @carlson_spencer
Thanks for raising your concern via Forum.
There is no specific Milling post for 'DMG DMU 50'  with Siemens controller in HSM post library.
I think Siemens SINUMERIK 840D post in HSM library would be reasonably close to your machine NC program. You can download the same in below link:
https://cam.autodesk.com/hsmposts?p=siemens-840d
Change the kinematics of the post to suit DMG DMU 50
1. Search  'onOpen'
change the kinematic of post from this:
 if (false) {
    var aAxis = createAxis({coordinate:0, table:true, axis:[1, 0, 0], range:[-120.0001, 120.0001], preference:1});
    //var bAxis = createAxis({coordinate:1, table:true, axis:[0, 1, 0], range:[-120.0001, 120.0001], preference:1});
    var cAxis = createAxis({coordinate:2, table:true, axis:[0, 0, 1], range:[0, 360], cyclic:true});
    machineConfiguration = new MachineConfiguration(aAxis, cAxis);
to this:
if (true) {
    //var aAxis = createAxis({coordinate:0, table:true, axis:[1, 0, 0], range:[-120.0001, 120.0001], preference:1});
    machineConfiguration = new MachineConfiguration(bAxis, cAxis);
For detail info about the post editing please refer the  FAQ link
Regards
Arun.RS
Technical Consultant - Post Processor
Message 3 of 10
I have a post that I've modified extensively for our 1st generation DMU 50s. The only thing that isnt working yet is automatic probing
Message 4 of 10
carlson_spencer
Any way you can DM me the files? Thanks! I’m hoping everything from the first gen to the third is roughly the same!
Message 5 of 10
yeah just change your B axis limit because I believe yours goes more negative than the first generation. and change your home positions
Message 6 of 10
Hey man, how is that post working for you?
Message 7 of 10
marius_micromet
Hi
Does it work in 5 continuous axes ???
I also have a DMU50 sinumerik 840D -5 continuous axes and I am interested in a processor station that runs in 5 axes
Message 8 of 10
in reply to: marius_micromet
Yes sir. Check to make sure you don't have the 3rd generation DMU50. If you do, then the B axis negative limit is greater, so you'll have to change that. But it's an easy change. A word of caution however: always try to program continuous 5 axis toolpaths to avoid over-travelling in the negative B. Doing so will either alarm out when you go to post, or trigger the rewind logic which can be used but I personally have no experience with it and I added that code to the post manually. So whether it works perfectly or not is questionable
Message 9 of 10
marius_micromet
Hi
I tested the postprocessor and it works.
Exactly the 3rd generation DMU I have.
How to change the negative stroke limit of the B axis
Message 10 of 10
Did you ever figure out how to edit the home positions to the correct ones and extend the b axis limits?
Technology Administrators
