I have an Acu-rite G2 controller and use the 3 axis Acu-rite post processor. Is there a way i can edit the post so it always has coolant disabled? My machine has no coolant option, and I frequently forget to set it to disabled when I post.
Jeff
Solved by Arun.rs. Go to Solution.
Hi @vitreousity ,
You can disable a coolant code by ignoring the following codes in function onSection,
// set coolant after we have positioned at Z
// setCoolant(tool.coolant);
Or you can disable a coolant in the tool library (in Cutting data).
Hi @vitreousity
The easiest way to remove coolant codes from your postprocessor is to comment the command line :
//setCoolant(tool.coolant);
2. Same for setCoolant(COOLANT_OFF);
//setCoolant(COOLANT_OFF);
Regards
