DATRON M8 Post processor
Ryan_Fab
Message 1 of 19
Ryan_Fab
Would anybody happen to have and be kind enough to share a post for the Datron M8.
The ones available for download are no good for me, as my machine is a 2004 and has software version v7.06r
TIA
Replies (18)
Message 2 of 19
mmilleratticus
Did you ever get the post?
Message 3 of 19
Ryan_Fab
No I’m afraid not. Are you you looking for one too?
Message 4 of 19
AchimN
Which post are you using and which issues do you have with the post?
Achim.N
Principal Technology Consultant
Message 5 of 19
Ryan_Fab
I'm not able to use any of the ones available.
There isnt anything that caters for Software Version 7.06
Message 6 of 19
AchimN
The posts should be compatible with that version as well, so it would be good to know what kind of issues you have.
Achim.N
Message 7 of 19
Ryan_Fab
Are you able to link me to the post you think should work?
Message 8 of 19
AchimN
Sure, here it it:
https://cam.autodesk.com/hsmposts?p=datron_mcr
Achim.N
Message 9 of 19
Ryan_Fab
Thanks but this is the one Im having issues with.
Ive attached the generated code from your suggested post and a code generated by EdgeCam
The photo shows what remains of the fusion code when I load it on the Datron
Message 10 of 19
Ryan_Fab
and the fusion output
Message 11 of 19
Ryan_Fab
Sorry, the code attachments don't seem to be uploading? Maybe Im breaking a rule?
Message 12 of 19
AchimN
Not sure but maybe this is causing the issue, but please have a look at the screenshot attached. There is an option in the properties for the dialog setting, try to set that to "disabled" or "checkbox". Maybe your version does not support these dropdown dialogs.
Achim.N
Message 13 of 19
mmilleratticus
I'm out of the shop today. I'll give more information tomorrow if that's okay.
Message 14 of 19
mmilleratticus
Finally circling back...mistake was on my end.  Post works fine now that the user knows how to use it.
My machine does not support some of the smoothing or dynamic mode.  Machine would gag when program was posted with those features active.
Message 15 of 19
infoEUT8Z
My Datron M5 also doesn't work with one of these Fusion PP and needs a good one. Could you post here the Fusion PP that works with your M8? Many thanks
Message 16 of 19
mmilleratticus
I'm sorry to report I no longer have the M8 machine.  Maybe you can ask Adrien Montero at Datron to help you diagnose the issue with your post?
Message 17 of 19
infoEUT8Z
Thank You very much for your quick respond. If You still using Fusion 3600, maybe it is still saved in Your personal PP Library?
Message 18 of 19
mmilleratticus
No, I checked before I replied. It's lost to history. I'd ask Adrien Montero...he's really good with Fusion 360.
Message 19 of 19
infoEUT8Z
Thank You. I am looking already for his contakt.
