Change "notes" into NC code
FTKnur
FTKnur
I want to change all lines that begins with "#" to change into a direct NC-Code:
Check tool!
#Q215=2
should look in the NC-Code:
;Check tool     <-- Comment
Q215=2            <-- NC-Code
I tried a little bit with this post:
https://forums.autodesk.com/t5/hsm-post-processor-forum/control-variable-thru-notes/m-p/6373339#M992...
but I don't get it to work.
Can someone help me with this?
original PP:
  if (properties.showNotes && hasParameter("notes")) {
    var notes = getParameter("notes");
    if (notes) {
      var lines = String(notes).split("\n");
      var r1 = new RegExp("^[\\s]+", "g");
      var r2 = new RegExp("[\\s]+$", "g");
      for (line in lines) {
        var comment = lines[line].replace(r1, "").replace(r2, "");
        if (comment) {
          writeComment(comment);
makko74
Hallo @FTKnur,
mal mit folgendem Codeschnippsel versuchen..
    if (notes) {
        var zeile = lines[line].replace(r1, "").replace(r2, "");
        if (zeile[0]=="#") {
          writeBlock( zeile.split("#")[1].trim() );
        } else {
          writeComment( zeile );
Gruß
Mario
InfoInventor CAM(Ultimate) user --- Inventor Professional 2021.2 + Inventor CAM Ultimate 8.1.2.21785
GeorgeRoberts
Thanks for posting! Perhaps this code will do what you are looking for:
  if (hasParameter("notes")) {
    var lines = notes.split("\n");
    for (var i = 0; i < lines.length; ++i) {
      if (lines[i].charAt(0) == "#") {
        writeBlock(lines[i].substr(1, lines[i].length - 1));
      } else {
        writeComment(lines[i]);
George Roberts
Manufacturing Product manager
If you'd like to provide feedback and discuss how you would like things to be in the future, Email Me and we can arrange a virtual meeting!
FTKnur
Vielen dank @makko74,
hat genau das bewirkt, was ich wollte 🙂
Thanks @GeorgeRoberts,
yours works too but add after each comment line a blank line in the code. This from Mario works perfect!
