I'm working on a post for a Kiheung Machine. The machine has a A/B Head. It's controlled by Cycel19 but Kiheung makes use of a own cycle to rotate the head. For Example;
CYCL DEF 19.0
CYCL DEF A+0 B+270 C+0
CYCL DEF 302 Cycle 302
Q1501=+270 ; Up head Angle
Q1502=+0 ; Low head Angle
Q1503=+0 ; Up head direction
Q1504=+0 ; Low head direction
Anyone knows how to add these lines?
Solved by Laurens-3DTechDraw. Go to Solution.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Would it be possible for you to publish the postprocessor?
Or the points that have been adjusted.
I would be interested in how msn solves this.
