Creating/modifying post processor
Hello everyone,
I have  C.B. Ferrari - E520 machine (milling) and I did not find a post processor for it in Hsm inventor library.
I am thinking about using the post processor of Selca and try to adapt it but there are many functions that I need for my machine that I did not find in Selca.
Does someone have an idea about the right or the most suitable post processor that I need to use and adapt for my machine ?
Thank you for your attention.
alexander.munz
Hello @Anonymous,
I think the machine has a Siemens or Heidenhain control,
there are some PP's available.
Greetings Alex
Ihr fandet einen Beitrag hilfreich? Dann vergebt dafür doch Likes!
Eure Frage wurde erfolgreich gelöst? Dann einfach auf den 'Als Lösung akzeptieren'-Button klicken!
You found a post helpful? Then forgive Likes!
Your question was solved successfully? Then just click on the 'accept as solution' button!
Hello @alexander.munz,
I would like to thank you for your response, it is very nice from you.
But the problem I have is that the control is cb ferrari also and I have not found any post processor in the library for this machine.
I have a post processor for cb ferrari when I was using alphacam, but now that I am using hsm inventor I need to have a PP for this software.
Do you have an idea about how can I adapt this old PP ( for alphacam ) to hsm inventor ?
Have a good day
alexander.munz
Hello @Anonymous,
Do you have a G and M code list and a programming guide for this controller?
If so, then you could adjust a PP.
Greetings Alex
Thank your for your response, yes I have the list of functions G and M for the controller of my machine, I have also the PP that we used to use with an other software of CAM.
But I could not program a new PP who looks like the PP in the library of Inventor HSM, I used the PP of Selca and I am trying to delete the functions that I dont have.
The problem is I could not add new functions for some operations 😞
