Just wondering if anyone can help me with this?
After a recent update of Fusion 360 , I am unable to change the configuration of the post processor to suit my machine.
In the past after I drew a part, I was able to go to the manufacture tab and select what I wanted the machine to do, after that I went to post process and change the config (circled in image below) but now it appears to be inaccessible
Anyone else have the same issue
Any help would be greatly appreciated
Solved by boopathi.sivakumar. Go to Solution.
Hi @Anonymous
The default installed library will be an read only library. If you want to make any changes to the post then you need to copy the post processor to different location to modify it.
