Copyright (C) 2012-2017 by Autodesk, Inc.
All rights reserved.
FANUC post processor configuration.
$Revision: 41602 8a235290846bfe71ead6a010711f4fc730f48827 $
$Date: 2017-09-14 12:16:32 $
FORKID {04622D27-72F0-45d4-85FB-DB346FD1AE22}
description = "FANUC - Inverse Time and A-axis";
vendor = "Fanuc";
vendorUrl = "
http://www.fanuc.com";
legal = "Copyright (C) 2012-2017 by Autodesk, Inc.";
certificationLevel = 2;
minimumRevision = 24000;
longDescription = "Fanuc post illustrating inverse time feed with an A-axis.";
extension = "nc";
programNameIsInteger = true;
setCodePage("ascii");
capabilities = CAPABILITY_MILLING;
tolerance = spatial(0.002, MM);
minimumChordLength = spatial(0.01, MM);
minimumCircularRadius = spatial(0.01, MM);
maximumCircularRadius = spatial(1000, MM);
minimumCircularSweep = toRad(0.01);
maximumCircularSweep = toRad(180);
allowHelicalMoves = true;
allowedCircularPlanes = undefined; // allow any circular motion
// user-defined properties
properties = {
writeMachine: true, // write machine
writeTools: true, // writes the tools
preloadTool: true, // preloads next tool on tool change if any
showSequenceNumbers: true, // show sequence numbers
sequenceNumberStart: 10, // first sequence number
sequenceNumberIncrement: 5, // increment for sequence numbers
optionalStop: true, // optional stop
o8: false, // specifies 8-digit program number
useIncremental: true, // specifies that incremental XYZABC should be output.
separateWordsWithSpace: true, // specifies that the words should be separated with a white space
allow3DArcs: false, // specifies that 3D circular arcs are allowed
useRadius: false, // specifies that arcs should be output using the radius (R word) instead of the I, J, and K words
forceIJK: false, // force output of IJK for G2/G3 when not using R word
showNotes: false, // specifies that operation notes should be output
useSmoothing: false, // specifies if smoothing should be used or not
usePitchForTapping: false, // enable to use pitch instead of feed for the F-word for canned tapping cycles - note that your CNC control must be setup for pitch mode!
useG95: false, // use IPR/MPR instead of IPM/MPM
useG54x4: false, // Fanuc 30i supports G54.4 for Workpiece Error Compensation
makeAAxisOtherWay: false // make the A-axis rotate the opposite way
// user-defined property definitions
propertyDefinitions = {
writeMachine: {title:"Write machine", description:"Output the machine settings in the header of the code.", group:0, type:"boolean"},
writeTools: {title:"Write tool list", description:"Output a tool list in the header of the code.", group:0, type:"boolean"},
preloadTool: {title:"Preload tool", description:"Preloads the next tool at a tool change (if any).", group:1, type:"boolean"},
showSequenceNumbers: {title:"Use sequence numbers", description:"Use sequence numbers for each block of outputted code.", group:1, type:"boolean"},
sequenceNumberStart: {title:"Start sequence number", description:"The number at which to start the sequence numbers.", group:1, type:"integer"},
sequenceNumberIncrement: {title:"Sequence number increment", description:"The amount by which the sequence number is incremented by in each block.", group:1, type:"integer"},
optionalStop: {title:"Optional stop", description:"Outputs optional stop code during when necessary in the code.", type:"boolean"},
o8: {title:"8 Digit program number", description:"Specifies that an 8 digit program number is needed.", type:"boolean"},
separateWordsWithSpace: {title:"Separate words with space", description:"Adds spaces between words if 'yes' is selected.", type:"boolean"},
allow3DArcs: {title:"Allow 3D arcs", description:"Specifies whether 3D circular arcs are allowed.", type:"boolean"},
useIncremental: {title:"Use Incremental", description:"Specifies whether incremental XYZABC should be output.", type:"boolean"},
useRadius: {title:"Radius arcs", description:"If yes is selected, arcs are outputted using radius values rather than IJK.", type:"boolean"},
forceIJK: {title:"Force IJK", description:"Force the output of IJK for G2/G3 when not using R mode.", type:"boolean"},
showNotes: {title:"Show notes", description:"Writes operation notes as comments in the outputted code.", type:"boolean"},
useSmoothing: {title:"Use smoothing", description:"Specifies if smoothing should be used or not.", type:"boolean"},
usePitchForTapping: {title:"Force IJK", description:"Enables the use of pitch instead of feed for the F-word in canned tapping cycles. Your CNC control must be setup for pitch mode!", type:"boolean"},
useG95: {title:"Use G95", description:"Use IPR/MPR instead of IPM/MPM.", type:"boolean"},
useG54x4: {title:"Use G54.4", description:"Fanuc 30i supports G54.4 for workpiece error compensation.", type:"boolean"},
makeAAxisOtherWay: {title:"Reverse A-axis", description:"Makes the A-axis rotate the opposite way.", type:"boolean"}
var permittedCommentChars = " ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789.,=_-";
var gFormat = createFormat({prefix:"G", width:2, zeropad:true, decimals:1});
var mFormat = createFormat({prefix:"M", width:2, zeropad:true, decimals:1});
var hFormat = createFormat({prefix:"H", width:2, zeropad:true, decimals:1});
var dFormat = createFormat({prefix:"D", width:2, zeropad:true, decimals:1});
var probe100Format = createFormat({decimals:3, zeropad:true, width:3, forceDecimal:true});
var xyzFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true});
var rFormat = xyzFormat; // radius
var abcFormat = createFormat({decimals:3, forceDecimal:true, scale:DEG});
var feedFormat = createFormat({decimals:(unit == MM ? 1 : 2), forceDecimal:true});
var pitchFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true});
var toolFormat = createFormat({decimals:0});
var rpmFormat = createFormat({decimals:0});
var secFormat = createFormat({decimals:3, forceDecimal:true}); // seconds - range 0.001-99999.999
var milliFormat = createFormat({decimals:0}); // milliseconds // range 1-9999
var taperFormat = createFormat({decimals:1, scale:DEG});
var xOutput = createVariable({prefix:"X"}, xyzFormat);
var yOutput = createVariable({prefix:"Y"}, xyzFormat);
var zOutput = createVariable({prefix:"Z"}, xyzFormat);
var aOutput = createVariable({prefix:"A"}, abcFormat);
var bOutput = createVariable({prefix:"B"}, abcFormat);
var cOutput = createVariable({prefix:"C"}, abcFormat);
var feedOutput = createVariable({prefix:"F"}, feedFormat);
var pitchOutput = createVariable({prefix:"F", force:true}, pitchFormat);
var inverseTimeOutput = createVariable({prefix:"F", force:true}, feedFormat);
var sOutput = createVariable({prefix:"S", force:true}, rpmFormat);
var dOutput = createVariable({}, dFormat);
// circular output
var iOutput = createReferenceVariable({prefix:"I"}, xyzFormat);
var jOutput = createReferenceVariable({prefix:"J"}, xyzFormat);
var kOutput = createReferenceVariable({prefix:"K"}, xyzFormat);
var gMotionModal = createModal({}, gFormat); // modal group 1 // G0-G3, ...
var gPlaneModal = createModal({onchange:function () {gMotionModal.reset();}}, gFormat); // modal group 2 // G17-19
var gAbsIncModal = createModal({}, gFormat); // modal group 3 // G90-91
var gFeedModeModal = createModal({}, gFormat); // modal group 5 // G94-95
var gUnitModal = createModal({}, gFormat); // modal group 6 // G20-21
var gCycleModal = createModal({}, gFormat); // modal group 9 // G81, ...
var gRetractModal = createModal({}, gFormat); // modal group 10 // G98-99
var gRotationModal = createModal({force:true}, gFormat); // modal group 16 // G68-G69
// fixed settings
var useMultiAxisFeatures = false;
var forceMultiAxisIndexing = false; // force multi-axis indexing for 3D programs
var WARNING_WORK_OFFSET = 0;
var ANGLE_PROBE_NOT_SUPPORTED = 0;
var ANGLE_PROBE_USE_ROTATION = 1;
var ANGLE_PROBE_USE_CAXIS = 2;
// collected state
var sequenceNumber;
var currentWorkOffset;
var optionalSection = false;
var useIncremental = false;
var forceSpindleSpeed = false;
var g68RotationMode = 0;
var angularProbingMode;
Writes the specified block.
function writeBlock() {
if (properties.showSequenceNumbers) {
if (optionalSection) {
var text = formatWords(arguments);
if (text) {
writeWords("/", "N" + sequenceNumber, text);
} else {
writeWords2("N" + sequenceNumber, arguments);
sequenceNumber += properties.sequenceNumberIncrement;
} else {
writeWords2("/", arguments);
} else {
writeWords(arguments);
Writes the specified optional block.
function writeOptionalBlock() {
var words = formatWords(arguments);
if (words) {
writeWords("/", "N" + sequenceNumber, words);
} else {
function formatComment(text) {
return "(" + filterText(String(text).toUpperCase(), permittedCommentChars).replace(/[\(\)]/g, "") + ")";
Output a comment.
function writeComment(text) {
writeln(formatComment(text));
function onOpen() {
if (properties.useRadius) {
maximumCircularSweep = toRad(90); // avoid potential center calculation errors for CNC
if (true) {
var aAxis = createAxis({coordinate:0, table:true, axis:[(properties.makeAAxisOtherWay ? -1 : 1) * -1, 0, 0], cyclic:true, preference:1});
machineConfiguration = new MachineConfiguration(aAxis);
setMachineConfiguration(machineConfiguration);
optimizeMachineAngles2(1); // map tip mode
if (!machineConfiguration.isMachineCoordinate(0)) {
aOutput.disable();
if (!machineConfiguration.isMachineCoordinate(1)) {
bOutput.disable();
if (!machineConfiguration.isMachineCoordinate(2)) {
cOutput.disable();
if (!properties.separateWordsWithSpace) {
setWordSeparator("");
if (properties.forceIJK) {
iOutput = createReferenceVariable({prefix:"I", force:true}, xyzFormat);
jOutput = createReferenceVariable({prefix:"J", force:true}, xyzFormat);
kOutput = createReferenceVariable({prefix:"K", force:true}, xyzFormat);
sequenceNumber = properties.sequenceNumberStart;
writeln("%");
if (programName) {
var programId;
try {
programId = getAsInt(programName);
} catch(e) {
error(localize("Program name must be a number."));
return;
if (properties.o8) {
if (!((programId >= 1) && (programId <= 99999999))) {
error(localize("Program number is out of range."));
return;
} else {
if (!((programId >= 1) && (programId <= 9999))) {
return;
if ((programId >= 8000) && (programId <= 9999)) {
warning(localize("Program number is reserved by tool builder."));
var oFormat = createFormat({width:(properties.o8 ? 8 : 4), zeropad:true, decimals:0});
if (programComment) {
writeln("O" + oFormat.format(programId) + " (" + filterText(String(programComment).toUpperCase(), permittedCommentChars) + ")");
} else {
writeln("O" + oFormat.format(programId));
} else {
error(localize("Program name has not been specified."));
return;
// dump machine configuration
var vendor = machineConfiguration.getVendor();
var model = machineConfiguration.getModel();
var description = machineConfiguration.getDescription();
if (properties.writeMachine && (vendor || model || description)) {
writeComment(localize("Machine"));
if (vendor) {
writeComment(" " + localize("vendor") + ": " + vendor);
if (model) {
writeComment(" " + localize("model") + ": " + model);
if (description) {
writeComment(" " + localize("description") + ": " + description);
// dump tool information
if (properties.writeTools) {
var zRanges = {};
if (is3D()) {
var numberOfSections = getNumberOfSections();
for (var i = 0; i < numberOfSections; ++i) {
var section = getSection(i);
var zRange = section.getGlobalZRange();
var tool = section.getTool();
if (zRanges[tool.number]) {
zRanges[tool.number].expandToRange(zRange);
} else {
zRanges[tool.number] = zRange;
var tools = getToolTable();
if (tools.getNumberOfTools() > 0) {
for (var i = 0; i < tools.getNumberOfTools(); ++i) {
var tool = tools.getTool(i);
var comment = "T" + toolFormat.format(tool.number) + " " +
"D=" + xyzFormat.format(tool.diameter) + " " +
localize("CR") + "=" + xyzFormat.format(tool.cornerRadius);
if ((tool.taperAngle > 0) && (tool.taperAngle < Math.PI)) {
comment += " " + localize("TAPER") + "=" + taperFormat.format(tool.taperAngle) + localize("deg");
comment += " - " + localize("ZMIN") + "=" + xyzFormat.format(zRanges[tool.number].getMinimum());
comment += " - " + getToolTypeName(tool.type);
writeComment(comment);
if (false) {
// check for duplicate tool number
for (var i = 0; i < getNumberOfSections(); ++i) {
var sectioni = getSection(i);
var tooli = sectioni.getTool();
for (var j = i + 1; j < getNumberOfSections(); ++j) {
var sectionj = getSection(j);
var toolj = sectionj.getTool();
if (tooli.number == toolj.number) {
if (xyzFormat.areDifferent(tooli.diameter, toolj.diameter) ||
xyzFormat.areDifferent(tooli.cornerRadius, toolj.cornerRadius) ||
abcFormat.areDifferent(tooli.taperAngle, toolj.taperAngle) ||
(tooli.numberOfFlutes != toolj.numberOfFlutes)) {
error(
subst(
localize("Using the same tool number for different cutter geometry for operation '%1' and '%2'."),
sectioni.hasParameter("operation-comment") ? sectioni.getParameter("operation-comment") : ("#" + (i + 1)),
sectionj.hasParameter("operation-comment") ? sectionj.getParameter("operation-comment") : ("#" + (j + 1))
return;
if ((getNumberOfSections() > 0) && (getSection(0).workOffset == 0)) {
if (getSection(i).workOffset > 0) {
error(localize("Using multiple work offsets is not possible if the initial work offset is 0."));
return;
// absolute coordinates and feed per min
writeBlock(gAbsIncModal.format(90), gFeedModeModal.format(properties.useG95 ? 95 : 94), gPlaneModal.format(17), gFormat.format(49), gFormat.format(40), gFormat.format(80));
switch (unit) {
case IN:
writeBlock(gUnitModal.format(20));
break;
case MM:
writeBlock(gUnitModal.format(21));
break;
if (properties.useG95) {
feedFormat = createFormat({decimals:(unit == MM ? 4 : 5), forceDecimal:true});
function onComment(message) {
var comments = String(message).split(";");
for (comment in comments) {
writeComment(comments[comment]);
/** Force output of X, Y, and Z. */
function forceXYZ() {
xOutput.reset();
yOutput.reset();
zOutput.reset();
/** Force output of A, B, and C. */
function forceABC() {
aOutput.reset();
bOutput.reset();
cOutput.reset();
function forceFeed() {
feedOutput.reset();
/** Force output of X, Y, Z, A, B, C, and F on next output. */
function forceAny() {
forceXYZ();
forceABC();
forceFeed();
var lengthCompensationActive = false;
var retracted = false; // specifies that the tool has been retracted to the safe plane
/** Disables length compensation if currently active or if forced. */
function disableLengthCompensation(force) {
if (lengthCompensationActive || force) {
validate(retracted, "Cannot cancel length compensation if the machine is not fully retracted.");
writeBlock(gFormat.format(49));
var currentSmoothing = false;
function setSmoothing(mode) {
if (mode == currentSmoothing) {
return false;
// 1) Make sure G49 is called before the execution of G05.1 Q1 Rx
// 2) G05.1 Q1 Rx must be engaged BEFORE G43-Tool Length Comp
// 3) AICC and AIAPC need to be turned on and off for each tool
// 4) AICC and AIAPC does not apply to canned drilling cycles
validate(!lengthCompensationActive, "Length compensation is active while trying to update smoothing.");
currentSmoothing = mode;
writeBlock(gFormat.format(5.1), mode ? "Q1" : "Q0");
return true;
var currentWorkPlaneABC = undefined;
function forceWorkPlane() {
function setWorkPlane(abc) {
if (!forceMultiAxisIndexing && is3D() && !machineConfiguration.isMultiAxisConfiguration()) {
return; // ignore
if (!((currentWorkPlaneABC == undefined) ||
abcFormat.areDifferent(abc.x, currentWorkPlaneABC.x) ||
abcFormat.areDifferent(abc.y, currentWorkPlaneABC.y) ||
abcFormat.areDifferent(abc.z, currentWorkPlaneABC.z))) {
return; // no change
onCommand(COMMAND_UNLOCK_MULTI_AXIS);
if (useMultiAxisFeatures) {
if (abc.isNonZero()) {
writeBlock(gFormat.format(68.2), "X" + xyzFormat.format(0), "Y" + xyzFormat.format(0), "Z" + xyzFormat.format(0), "A" + abcFormat.format(abc.x), "B" + abcFormat.format(abc.y), "C" + abcFormat.format(abc.z)); // set frame
writeBlock(gFormat.format(53.1)); // turn machine
} else {
writeBlock(gFormat.format(69)); // cancel frame
} else {
writeBlock(
gMotionModal.format(0),
conditional(machineConfiguration.isMachineCoordinate(0), "A" + abcFormat.format(abc.x)),
conditional(machineConfiguration.isMachineCoordinate(1), "B" + abcFormat.format(abc.y)),
conditional(machineConfiguration.isMachineCoordinate(2), "C" + abcFormat.format(abc.z))
onCommand(COMMAND_LOCK_MULTI_AXIS);
currentWorkPlaneABC = abc;
var closestABC = false; // choose closest machine angles
var currentMachineABC;
function getWorkPlaneMachineABC(workPlane) {
var W = workPlane; // map to global frame
var abc = machineConfiguration.getABC(W);
if (closestABC) {
if (currentMachineABC) {
abc = machineConfiguration.remapToABC(abc, currentMachineABC);
} else {
abc = machineConfiguration.getPreferredABC(abc);
} else {
try {
abc = machineConfiguration.remapABC(abc);
currentMachineABC = abc;
} catch (e) {
error(
localize("Machine angles not supported") + ":"
+ conditional(machineConfiguration.isMachineCoordinate(0), " A" + abcFormat.format(abc.x))
+ conditional(machineConfiguration.isMachineCoordinate(1), " B" + abcFormat.format(abc.y))
+ conditional(machineConfiguration.isMachineCoordinate(2), " C" + abcFormat.format(abc.z))
var direction = machineConfiguration.getDirection(abc);
if (!isSameDirection(direction, W.forward)) {
error(localize("Orientation not supported."));
if (!machineConfiguration.isABCSupported(abc)) {
error(
localize("Work plane is not supported") + ":"
var tcp = false;
if (tcp) {
setRotation(W); // TCP mode
} else {
var O = machineConfiguration.getOrientation(abc);
var R = machineConfiguration.getRemainingOrientation(abc, W);
setRotation(R);
return abc;
function isProbeOperation() {
return (hasParameter("operation-strategy") &&
getParameter("operation-strategy") == "probe");
var probeOutputWorkOffset = 1;
function onParameter(name, value) {
if (name == "probe-output-work-offset") {
probeOutputWorkOffset = (value > 0) ? value : 1;
function onSection() {
var forceToolAndRetract = optionalSection && !currentSection.isOptional();
optionalSection = currentSection.isOptional();
var insertToolCall = forceToolAndRetract || isFirstSection() ||
currentSection.getForceToolChange && currentSection.getForceToolChange() ||
(tool.number != getPreviousSection().getTool().number);
var newWorkOffset = isFirstSection() ||
(getPreviousSection().workOffset != currentSection.workOffset); // work offset changes
var newWorkPlane = isFirstSection() ||
!isSameDirection(getPreviousSection().getGlobalFinalToolAxis(), currentSection.getGlobalInitialToolAxis());
var forceSmoothing = properties.useSmoothing &&
(hasParameter("operation-strategy") && (getParameter("operation-strategy") == "drill") ||
!isFirstSection() && getPreviousSection().hasParameter("operation-strategy") && (getPreviousSection().getParameter("operation-strategy") == "drill")); // force smoothing in case !insertToolCall (2d chamfer)
if (insertToolCall || newWorkOffset || newWorkPlane || forceSmoothing) {
// stop spindle before retract during tool change
if (insertToolCall && !isFirstSection()) {
onCommand(COMMAND_STOP_SPINDLE);
// retract to safe plane
retracted = true;
writeBlock(gFormat.format(28), gAbsIncModal.format(91), "Z" + xyzFormat.format(0)); // retract
writeBlock(gAbsIncModal.format(90));
forceXYZ();
if ((insertToolCall && !isFirstSection()) || forceSmoothing) {
disableLengthCompensation();
setSmoothing(false);
writeln("");
if (hasParameter("operation-comment")) {
var comment = getParameter("operation-comment");
if (comment) {
if (properties.showNotes && hasParameter("notes")) {
var notes = getParameter("notes");
if (notes) {
var lines = String(notes).split("\n");
var r1 = new RegExp("^[\\s]+", "g");
var r2 = new RegExp("[\\s]+$", "g");
for (line in lines) {
var comment = lines[line].replace(r1, "").replace(r2, "");
if (comment) {
if (insertToolCall) {
forceWorkPlane();
retracted = true;
onCommand(COMMAND_COOLANT_OFF);
if (!isFirstSection() && properties.optionalStop) {
onCommand(COMMAND_OPTIONAL_STOP);
if (tool.number > 99) {
warning(localize("Tool number exceeds maximum value."));
writeBlock("T" + toolFormat.format(tool.number), mFormat.format(6));
if (tool.comment) {
writeComment(tool.comment);
var showToolZMin = false;
if (showToolZMin) {
if (is3D()) {
var zRange = currentSection.getGlobalZRange();
var number = tool.number;
for (var i = currentSection.getId() + 1; i < numberOfSections; ++i) {
if (section.getTool().number != number) {
break;
zRange.expandToRange(section.getGlobalZRange());
writeComment(localize("ZMIN") + "=" + zRange.getMinimum());
if (properties.preloadTool) {
var nextTool = getNextTool(tool.number);
if (nextTool) {
writeBlock("T" + toolFormat.format(nextTool.number));
} else {
// preload first tool
var section = getSection(0);
var firstToolNumber = section.getTool().number;
if (tool.number != firstToolNumber) {
writeBlock("T" + toolFormat.format(firstToolNumber));
if (!isProbeOperation() &&
(insertToolCall ||
forceSpindleSpeed ||
isFirstSection() ||
(rpmFormat.areDifferent(tool.spindleRPM, sOutput.getCurrent())) ||
(tool.clockwise != getPreviousSection().getTool().clockwise))) {
if (tool.spindleRPM < 1) {
error(localize("Spindle speed out of range."));
return;
if (tool.spindleRPM > 99999) {
warning(localize("Spindle speed exceeds maximum value."));
writeBlock(
sOutput.format(tool.spindleRPM), mFormat.format(tool.clockwise ? 3 : 4)
onCommand(COMMAND_START_CHIP_TRANSPORT);
if (forceMultiAxisIndexing || !is3D() || machineConfiguration.isMultiAxisConfiguration()) {
// writeBlock(mFormat.format(xxx)); // shortest path traverse
// wcs
if (insertToolCall) { // force work offset when changing tool
currentWorkOffset = undefined;
var workOffset = currentSection.workOffset;
if (workOffset == 0) {
warningOnce(localize("Work offset has not been specified. Using G54 as WCS."), WARNING_WORK_OFFSET);
workOffset = 1;
if (workOffset > 0) {
if (workOffset > 6) {
var p = workOffset - 6; // 1->...
if (p > 300) {
error(localize("Work offset out of range."));
return;
} else {
if (workOffset != currentWorkOffset) {
writeBlock(gFormat.format(54.1), "P" + p); // G54.1P
currentWorkOffset = workOffset;
} else {
writeBlock(gFormat.format(53 + workOffset)); // G54->G59
forceXYZ();
if (forceMultiAxisIndexing || !is3D() || machineConfiguration.isMultiAxisConfiguration()) { // use 5-axis indexing for multi-axis mode
// set working plane after datum shift
if (currentSection.isMultiAxis()) {
forceWorkPlane();
cancelTransformation();
} else {
var abc = new Vector(0, 0, 0);
var eulerXYZ = currentSection.workPlane.getTransposed().eulerZYX_R;
abc = new Vector(-eulerXYZ.x, -eulerXYZ.y, -eulerXYZ.z);
} else {
abc = getWorkPlaneMachineABC(currentSection.workPlane);
setWorkPlane(abc);
} else { // pure 3D
var remaining = currentSection.workPlane;
if (!isSameDirection(remaining.forward, new Vector(0, 0, 1))) {
error(localize("Tool orientation is not supported."));
return;
setRotation(remaining);
// set coolant after we have positioned at Z
setCoolant(tool.coolant);
if (properties.useSmoothing) {
if (hasParameter("operation-strategy") && (getParameter("operation-strategy") != "drill")) {
if (setSmoothing(true)) {
// we force G43 using lengthCompensationActive
} else {
if (setSmoothing(false)) {
forceAny();
var initialPosition = getFramePosition(currentSection.getInitialPosition());
if (!retracted) {
if (getCurrentPosition().z < initialPosition.z) {
writeBlock(gMotionModal.format(0), zOutput.format(initialPosition.z));
if (insertToolCall || !lengthCompensationActive || retracted || (!isFirstSection() && getPreviousSection().isMultiAxis())) {
var lengthOffset = tool.lengthOffset;
if (lengthOffset > 99) {
error(localize("Length offset out of range."));
return;
writeBlock(gPlaneModal.format(17));
if (!machineConfiguration.isHeadConfiguration()) {
writeBlock(
gMotionModal.format(0), xOutput.format(initialPosition.x), yOutput.format(initialPosition.y)
writeBlock(gMotionModal.format(0), gFormat.format(43), zOutput.format(initialPosition.z), hFormat.format(lengthOffset));
lengthCompensationActive = true;
} else {
writeBlock(
gFormat.format(43), xOutput.format(initialPosition.x),
yOutput.format(initialPosition.y),
} else {
writeBlock(
validate(lengthCompensationActive, "Length compensation is not active.");
if (isProbeOperation()) {
if (g68RotationMode != 0) {
error(localize("You cannot probe while G68 Rotation is in effect."));
return;
angularProbingMode = getAngularProbingMode();
writeBlock(gFormat.format(65), "P" + 9832); // spin the probe on
retracted = false;
if (properties.useIncremental) {
writeBlock(gAbsIncModal.format(91));
xOutput = createIncrementalVariable({prefix:"X"}, xyzFormat);
xOutput.format(initialPosition.x);
yOutput = createIncrementalVariable({prefix:"Y"}, xyzFormat);
yOutput.format(initialPosition.y);
zOutput = createIncrementalVariable({prefix:"Z"}, xyzFormat);
zOutput.format(initialPosition.z);
var abc = new Vector(); // TAG: set if using multi-axis machine
aOutput = createIncrementalVariable({prefix:"A"}, abcFormat);
aOutput.format(abc.x);
bOutput = createIncrementalVariable({prefix:"B"}, abcFormat);
bOutput.format(abc.y);
cOutput = createIncrementalVariable({prefix:"C"}, abcFormat);
cOutput.format(abc.z);
useIncremental = true;
} else {
function onDwell(seconds) {
if (seconds > 99999.999) {
warning(localize("Dwelling time is out of range."));
milliseconds = clamp(1, seconds * 1000, 99999999);
writeBlock(gFeedModeModal.format(94), gFormat.format(4), "P" + milliFormat.format(milliseconds));
writeBlock(gFeedModeModal.format(properties.useG95 ? 95 : 94)); // back to G95
function onSpindleSpeed(spindleSpeed) {
writeBlock(sOutput.format(spindleSpeed));
function onCycle() {
function getCommonCycle(x, y, z, r) {
forceXYZ(); // force xyz on first drill hole of any cycle
if (useIncremental) {
return [xOutput.format(x), yOutput.format(y),
"Z" + xyzFormat.format(z - r),
"R" + xyzFormat.format(r - zOutput.getCurrent())];
} else {
zOutput.format(z),
"R" + xyzFormat.format(r)];
/** Convert approach to sign. */
function approach(value) {
validate((value == "positive") || (value == "negative"), "Invalid approach.");
return (value == "positive") ? 1 : -1;
Determine if angular probing is supported
function getAngularProbingMode() {
if (machineConfiguration.isMultiAxisConfiguration()) {
if (machineConfiguration.isMachineCoordinate(2)) {
return ANGLE_PROBE_USE_CAXIS;
} else {
return ANGLE_PROBE_NOT_SUPPORTED;
} else {
return ANGLE_PROBE_USE_ROTATION;
Output rotation offset based on angular probing cycle.
function setProbingAngle() {
if ((g68RotationMode == 1) || (g68RotationMode == 2)) { // Rotate coordinate system for Angle Probing
if (!properties.useG54x4) {
gRotationModal.reset();
gAbsIncModal.reset();
writeBlock(
gRotationModal.format(68), gAbsIncModal.format(90),
(g68RotationMode == 1) ? "X0" : "X[#135]",
(g68RotationMode == 1) ? "Y0" : "Y[#136]",
"Z0", "I0.0", "J0.0", "K1.0", "R[#139]"
g68RotationMode = 3;
} else if (angularProbingMode != ANGLE_PROBE_NOT_SUPPORTED) {
writeBlock("#26010=#135");
writeBlock("#26011=#136");
writeBlock("#26012=#137");
writeBlock("#26015=#139");
writeBlock(gFormat.format(54.4), "P1");
} else {
error(localize("Angular probing is not supported for this machine configuration."));
return;
function onCyclePoint(x, y, z) {
var probeWorkOffsetCode;
var workOffset = probeOutputWorkOffset ? probeOutputWorkOffset : currentWorkOffset;
if (workOffset > 99) {
error(localize("Work offset is out of range."));
return;
} else if (workOffset > 6) {
probeWorkOffsetCode = probe100Format.format(workOffset - 6 + 100);
} else {
probeWorkOffsetCode = workOffset + "."; // G54->G59
if (isFirstCyclePoint()) {
repositionToCycleClearance(cycle, x, y, z);
// return to initial Z which is clearance plane and set absolute mode
var F = cycle.feedrate;
F /= spindleSpeed;
var P = (cycle.dwell == 0) ? 0 : clamp(1, cycle.dwell * 1000, 99999999); // in milliseconds
switch (cycleType) {
case "drilling":
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(useIncremental ? 91 : 90), gCycleModal.format(81),
getCommonCycle(x, y, z, cycle.retract),
feedOutput.format(F)
break;
case "counter-boring":
if (P > 0) {
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(useIncremental ? 91 : 90), gCycleModal.format(82),
"P" + milliFormat.format(P),
} else {
writeBlock(
break;
case "chip-breaking":
// cycle.accumulatedDepth is ignored
if (P > 0) {
expandCyclePoint(x, y, z);
} else {
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(useIncremental ? 91 : 90), gCycleModal.format(73),
"Q" + xyzFormat.format(cycle.incrementalDepth),
break;
case "deep-drilling":
if (P > 0) {
} else {
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(useIncremental ? 91 : 90), gCycleModal.format(83),
// conditional(P > 0, "P" + milliFormat.format(P)),
break;
case "tapping":
writeBlock(mFormat.format(29), sOutput.format(tool.spindleRPM));
if (properties.usePitchForTapping) {
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(useIncremental ? 91 : 90), gCycleModal.format((tool.type == TOOL_TAP_LEFT_HAND) ? 74 : 84),
pitchOutput.format(tool.threadPitch)
forceFeed();
} else {
writeBlock(
break;
case "left-tapping":
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(useIncremental ? 91 : 90), gCycleModal.format(74),
forceFeed();
} else {
writeBlock(
feedOutput.format(properties.useG95 ? tool.getTappingFeedrate()/spindleSpeed : tool.getTappingFeedrate())
break;
case "right-tapping":
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(useIncremental ? 91 : 90), gCycleModal.format(84),
forceFeed();
} else {
writeBlock(
break;
case "tapping-with-chip-breaking":
case "left-tapping-with-chip-breaking":
case "right-tapping-with-chip-breaking":
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(useIncremental ? 91 : 90), gCycleModal.format((tool.type == TOOL_TAP_LEFT_HAND ? 74 : 84)),
forceFeed();
} else {
writeBlock(
break;
case "fine-boring":
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(useIncremental ? 91 : 90), gCycleModal.format(76),
"P" + milliFormat.format(P), // not optional
"Q" + xyzFormat.format(cycle.shift),
break;
case "back-boring":
var dx = (gPlaneModal.getCurrent() == 19) ? cycle.backBoreDistance : 0;
var dy = (gPlaneModal.getCurrent() == 18) ? cycle.backBoreDistance : 0;
var dz = (gPlaneModal.getCurrent() == 17) ? cycle.backBoreDistance : 0;
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(useIncremental ? 91 : 90), gCycleModal.format(87),
getCommonCycle(x - dx, y - dy, z - dz, cycle.bottom),
break;
case "reaming":
if (P > 0) {
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(useIncremental ? 91 : 90), gCycleModal.format(89),
} else {
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(useIncremental ? 91 : 90), gCycleModal.format(85),
break;
case "stop-boring":
if (P > 0) {
} else {
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(useIncremental ? 91 : 90), gCycleModal.format(86),
break;
case "manual-boring":
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(useIncremental ? 91 : 90), gCycleModal.format(88),
break;
case "boring":
if (P > 0) {
writeBlock(
} else {
writeBlock(
break;
case "probing-x":
forceXYZ();
// move slowly always from clearance not retract
writeBlock(gFormat.format(65), "P" + 9810, zOutput.format(z - cycle.depth), feedOutput.format(F)); // protected positioning move
writeBlock(
gFormat.format(65), "P" + 9811,
"X" + xyzFormat.format(x + approach(cycle.approach1) * (cycle.probeClearance + tool.diameter/2)),
"Q" + xyzFormat.format(cycle.probeOvertravel),
"S" + probeWorkOffsetCode // "T" + toolFormat.format(probeToolDiameterOffset)
break;
case "probing-y":
forceXYZ();
writeBlock(
"Y" + xyzFormat.format(y + approach(cycle.approach1) * (cycle.probeClearance + tool.diameter/2)),
break;
case "probing-z":
forceXYZ();
writeBlock(gFormat.format(65), "P" + 9810, zOutput.format(Math.min(z - cycle.depth + cycle.probeClearance, cycle.retract)), feedOutput.format(F)); // protected positioning move
writeBlock(
"Z" + xyzFormat.format(z - cycle.depth),
"S" + probeWorkOffsetCode // "T" + toolFormat.format(probeToolLengthOffset)
break;
case "probing-x-wall":
writeBlock(gFormat.format(65), "P" + 9810, zOutput.format(z), feedOutput.format(F)); // protected positioning move
writeBlock(
gFormat.format(65), "P" + 9812,
"X" + xyzFormat.format(cycle.width1),
"R" + xyzFormat.format(cycle.probeClearance),
break;
case "probing-y-wall":
writeBlock(
"Y" + xyzFormat.format(cycle.width1),
break;
case "probing-x-channel":
writeBlock(
// not required "R" + xyzFormat.format(cycle.probeClearance),
break;
case "probing-x-channel-with-island":
writeBlock(
"R" + xyzFormat.format(-cycle.probeClearance),
break;
case "probing-y-channel":
yOutput.reset();
writeBlock(
break;
case "probing-y-channel-with-island":
yOutput.reset();
writeBlock(
break;
case "probing-xy-circular-boss":
writeBlock(
gFormat.format(65), "P" + 9814,
"D" + xyzFormat.format(cycle.width1),
break;
case "probing-xy-circular-hole":
writeBlock(
break;
case "probing-xy-circular-hole-with-island":
writeBlock(
break;
case "probing-xy-rectangular-hole":
writeBlock(
// not required "R" + xyzFormat.format(-cycle.probeClearance),
writeBlock(
"Y" + xyzFormat.format(cycle.width2),
break;
case "probing-xy-rectangular-boss":
writeBlock(
writeBlock(
break;
case "probing-xy-rectangular-hole-with-island":
writeBlock(
writeBlock(
break;
case "probing-xy-inner-corner":
var cornerX = x + approach(cycle.approach1) * (cycle.probeClearance + tool.diameter/2);
var cornerY = y + approach(cycle.approach2) * (cycle.probeClearance + tool.diameter/2);
var cornerI = 0;
var cornerJ = 0;
if (cycle.probeSpacing !== undefined) {
cornerI = cycle.probeSpacing;
cornerJ = cycle.probeSpacing;
if ((cornerI != 0) && (cornerJ != 0)) {
g68RotationMode = 2;
writeBlock(
gFormat.format(65), "P" + 9815, xOutput.format(cornerX), yOutput.format(cornerY),
conditional(cornerI != 0, "I" + xyzFormat.format(cornerI)),
conditional(cornerJ != 0, "J" + xyzFormat.format(cornerJ)),
conditional((g68RotationMode == 0) || (angularProbingMode == ANGLE_PROBE_USE_CAXIS), "S" + probeWorkOffsetCode)
break;
case "probing-xy-outer-corner":
var cornerI = 0;
var cornerJ = 0;
writeBlock(
gFormat.format(65), "P" + 9816, xOutput.format(cornerX), yOutput.format(cornerY),
break;
case "probing-x-plane-angle":
forceXYZ();
writeBlock(
gFormat.format(65), "P" + 9843,
"D" + xyzFormat.format(cycle.probeSpacing),
g68RotationMode = 1;
break;
case "probing-y-plane-angle":
forceXYZ();
writeBlock(
break;
default:
} else {
// do nothing
} else if (cycleExpanded) {
} else {
writeBlock(xOutput.format(x), yOutput.format(y));
function onCycleEnd() {
writeBlock(gFormat.format(65), "P" + 9810, zOutput.format(cycle.clearance)); // protected retract move
writeBlock(gFormat.format(65), "P" + 9833); // spin the probe off
setProbingAngle(); // define rotation of part
// we can move in rapid from retract optionally
} else if (!cycleExpanded) {
writeBlock(gCycleModal.format(80));
zOutput.reset();
var pendingRadiusCompensation = -1;
function onRadiusCompensation() {
pendingRadiusCompensation = radiusCompensation;
function onRapid(_x, _y, _z) {
var x = xOutput.format(_x);
var y = yOutput.format(_y);
var z = zOutput.format(_z);
if (x || y || z) {
if (pendingRadiusCompensation >= 0) {
error(localize("Radius compensation mode cannot be changed at rapid traversal."));
return;
writeBlock(gMotionModal.format(0), x, y, z);
forceFeed();
function onLinear(_x, _y, _z, feed) {
var f = feedOutput.format(feed);
if (x || y || z) {
var d = tool.diameterOffset;
if (d > 99) {
warning(localize("The diameter offset exceeds the maximum value."));
switch (radiusCompensation) {
case RADIUS_COMPENSATION_LEFT:
dOutput.reset();
writeBlock(gFeedModeModal.format(94), gMotionModal.format(1), gFormat.format(41), x, y, z, dOutput.format(d), f);
break;
case RADIUS_COMPENSATION_RIGHT:
dOutput.reset();
writeBlock(gFeedModeModal.format(94), gMotionModal.format(1), gFormat.format(42), x, y, z, dOutput.format(d), f);
break;
default:
writeBlock(gFeedModeModal.format(94), gMotionModal.format(1), gFormat.format(40), x, y, z, f);
} else {
writeBlock(gFeedModeModal.format(94), gMotionModal.format(1), x, y, z, f);
} else if (f) {
if (getNextRecord().isMotion()) { // try not to output feed without motion
forceFeed(); // force feed on next line
} else {
writeBlock(gFeedModeModal.format(94), gMotionModal.format(1), f);
function onRapid5D(_x, _y, _z, _a, _b, _c) {
return;
var a = aOutput.format(_a);
var b = bOutput.format(_b);
var c = cOutput.format(_c);
writeBlock(gMotionModal.format(0), x, y, z, a, b, c);
feedOutput.reset();
function onLinear5D(_x, _y, _z, _a, _b, _c, feed) {
if (!currentSection.isOptimizedForMachine()) {
error(localize("This post configuration has not been customized for 5-axis simultaneous toolpath."));
return;
error(localize("Radius compensation cannot be activated/deactivated for 5-axis move."));
return;
// get feedrate number
var f = {frn:0, fmode:0};
if (a || b || c) {
f = getMultiaxisFeed(_x, _y, _z, _a, _b, _c, feed);
} else {
f.frn = feedOutput.format(feed);
f.fmode = 94;
if (x || y || z || a || b || c) {
writeBlock(gFeedModeModal.format(f.fmode), gMotionModal.format(1), x, y, z, a, b, c, f.frn);
} else if (f.frn) {
feedOutput.reset(); // force feed on next line
} else {
writeBlock(gFeedModeModal.format(f.fmode), gMotionModal.format(1), f.frn);
// Start of multi-axis feedrate logic
/***** Be sure to add 'useInverseTime' to post properties if necessary. *****/
/***** 'inverseTimeOutput' must be defined. *****/
/***** 'headOffset' should be defined when a head rotary axis is defined. *****/
/***** The feedrate mode must be included in motion block output (linear, circular, etc. *****/
var dpmBPW = 0.1; // ratio of rotary accuracy to linear accuracy for DPM calculations
var inverseTimeUnits = 1.0; // 1.0 = minutes, 60.0 = seconds
var maxInverseTime = 9999; // maximum value to output for Inverse Time feeds
/** Calculate the multi-axis feedrate number. */
function getMultiaxisFeed(_x, _y, _z, _a, _b, _c, feed) {
if (feed <= 0) {
error(localize("Feedrate is less than or equal to 0."));
return f;
var length = getMoveLength(_x, _y, _z, _a, _b, _c);
if (true) { // inverse time
f.frn = inverseTimeOutput.format(getInverseTime(length[0], feed));
f.fmode = 93;
feedOutput.reset();
} else { // degrees per minute
f.frn = feedOutput.format(getFeedDPM(length, feed));
f.fmode = 94;
return f;
/** Calculate the DPM feedrate number. */
function getFeedDPM(_moveLength, _feed) {
// moveLength[0] = Tool tip, [1] = XYZ, [2] = ABC
if (false) { // TCP mode is supported, output feed as FPM
return feed;
} else { // DPM feedrate calculation
var moveTime = ((_moveLength[0] < 1.e-6) ? 0.001 : _moveLength[0]) / _feed;
var length = Math.sqrt(Math.pow(_moveLength[1], 2.0) + Math.pow((toDeg(_moveLength[2]) * dpmBPW), 2.0));
return length / moveTime;
/** Calculate the Inverse time feedrate number. */
function getInverseTime(_length, _feed) {
var inverseTime;
if (_length < 1.e-6) { // tool doesn't move
if (typeof maxInverseTime === "number") {
inverseTime = maxInverseTime;
} else {
inverseTime = 999999;
} else {
inverseTime = _feed / _length / inverseTimeUnits;
if (inverseTime > maxInverseTime) {
return inverseTime;
/** Calculate the distance of the tool position to the center of a rotary axis. */
function getRotaryRadius(center, direction, toolPosition) {
var normal = direction.getNormalized();
var d1 = toolPosition.x - center.x;
var d2 = toolPosition.y - center.y;
var d3 = toolPosition.z - center.z;
var radius = Math.sqrt(
Math.pow((d1 * normal.y) - (d2 * normal.x), 2.0) +
Math.pow((d2 * normal.z) - (d3 * normal.y), 2.0) +
Math.pow((d3 * normal.x) - (d1 * normal.z), 2.0)
return radius;
/** Calculate the linear distance based on the rotation of a rotary axis. */
function getRadialDistance(axis, startTool, endTool, startABC, endABC) {
// rotary axis does not exist
if (!axis.isEnabled()) {
return 0.0;
// calculate the rotary center based on head/table
var center;
if (axis.isHead()) {
var pivot;
if (typeof headOffset === "number") {
pivot = headOffset;
} else {
pivot = tool.getBodyLength();
center = Vector.sum(startTool, Vector.product(machineConfiguration.getSpindleAxis(), pivot));
center = Vector.sum(center, axis.getOffset());
} else {
center = axis.getOffset();
// calculate the radius of the tool end point compared to the rotary center
var startRadius = getRotaryRadius(center, axis.getEffectiveAxis(), startTool);
var endRadius = getRotaryRadius(center, axis.getEffectiveAxis(), endTool);
// calculate length of radial move
var radius = Math.max(startRadius, endRadius);
var delta = Math.abs(endABC.getCoordinate(axis.getCoordinate()) - startABC.getCoordinate(axis.getCoordinate()));
if (delta > Math.PI) {
delta = 2 * Math.PI - delta;
var radialLength = (2 * Math.PI * radius) * (delta / (2 * Math.PI));
return radialLength;
/** Calculate tooltip, XYZ, and rotary move lengths. */
function getMoveLength(_x, _y, _z, _a, _b, _c) {
// get starting and ending positions
var moveLength = new Array();
var startTool;
var endTool;
var startXYZ;
var endXYZ;
var startABC = getCurrentDirection();
var endABC = new Vector(_a, _b, _c);
if (currentSection.getOptimizedTCPMode() == 0) {
startTool = getCurrentPosition();
endTool = new Vector(_x, _y, _z);
startXYZ = machineConfiguration.getOrientation(startABC).getTransposed().multiply(startTool);
endXYZ = machineConfiguration.getOrientation(endABC).getTransposed().multiply(endTool);
} else {
startXYZ = getCurrentPosition();
endXYZ = new Vector(_x, _y, _z);
startTool = machineConfiguration.getOrientation(startABC).multiply(startXYZ);
endTool = machineConfiguration.getOrientation(endABC).multiply(endXYZ);
// calculate the radial portion of the move
var radialLength = Math.sqrt(
Math.pow(getRadialDistance(machineConfiguration.getAxisU(), startTool, endTool, startABC, endABC), 2.0) +
Math.pow(getRadialDistance(machineConfiguration.getAxisV(), startTool, endTool, startABC, endABC), 2.0) +
Math.pow(getRadialDistance(machineConfiguration.getAxisW(), startTool, endTool, startABC, endABC), 2.0)
// calculate the lengths of move
// tool tip distance is the move distance based on a combination of linear and rotary axes movement
var linearLength = Vector.diff(endXYZ, startXYZ).length;
moveLength[0] = linearLength + radialLength;
moveLength[1] = Vector.diff(endXYZ, startXYZ).length;
moveLength[2] = 0;
for (var i = 0; i < 3; ++i) {
var delta = Math.abs(endABC[i] - startABC[i]);
moveLength[2] += Math.pow(delta, 2.0);
moveLength[2] = Math.sqrt(moveLength[2]);
return moveLength;
// End of multi-axis feedrate logic
function onCircular(clockwise, cx, cy, cz, x, y, z, feed) {
error(localize("Radius compensation cannot be activated/deactivated for a circular move."));
return;
var start = getCurrentPosition();
if (isFullCircle()) {
if (properties.useRadius || isHelical()) { // radius mode does not support full arcs
linearize(tolerance);
return;
switch (getCircularPlane()) {
case PLANE_XY:
writeBlock(gAbsIncModal.format(useIncremental ? 91 : 90), gPlaneModal.format(17), gMotionModal.format(clockwise ? 2 : 3), iOutput.format(cx - start.x, 0), jOutput.format(cy - start.y, 0), getFeed(feed));
break;
case PLANE_ZX:
writeBlock(gAbsIncModal.format(useIncremental ? 91 : 90), gPlaneModal.format(18), gMotionModal.format(clockwise ? 2 : 3), iOutput.format(cx - start.x, 0), kOutput.format(cz - start.z, 0), getFeed(feed));
break;
case PLANE_YZ:
writeBlock(gAbsIncModal.format(useIncremental ? 91 : 90), gPlaneModal.format(19), gMotionModal.format(clockwise ? 2 : 3), jOutput.format(cy - start.y, 0), kOutput.format(cz - start.z, 0), getFeed(feed));
break;
default:
} else if (!properties.useRadius) {
case PLANE_XY:
writeBlock(gAbsIncModal.format(useIncremental ? 91 : 90), gPlaneModal.format(17), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), iOutput.format(cx - start.x, 0), jOutput.format(cy - start.y, 0), getFeed(feed));
break;
case PLANE_ZX:
writeBlock(gAbsIncModal.format(useIncremental ? 91 : 90), gPlaneModal.format(18), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), iOutput.format(cx - start.x, 0), kOutput.format(cz - start.z, 0), getFeed(feed));
break;
case PLANE_YZ:
writeBlock(gAbsIncModal.format(useIncremental ? 91 : 90), gPlaneModal.format(19), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), jOutput.format(cy - start.y, 0), kOutput.format(cz - start.z, 0), getFeed(feed));
break;
default:
if (properties.allow3DArcs) {
// make sure maximumCircularSweep is well below 360deg
// we could use G02.4 or G03.4 - direction is calculated
var ip = getPositionU(0.5);
writeBlock(gAbsIncModal.format(useIncremental ? 91 : 90), gMotionModal.format(clockwise ? 2.4 : 3.4), xOutput.format(ip.x), yOutput.format(ip.y), zOutput.format(ip.z), getFeed(feed));
writeBlock(xOutput.format(x), yOutput.format(y), zOutput.format(z));
} else {
} else { // use radius mode
var r = getCircularRadius();
if (toDeg(getCircularSweep()) > (180 + 1e-9)) {
r = -r; // allow up to <360 deg arcs
case PLANE_XY:
writeBlock(gAbsIncModal.format(useIncremental ? 91 : 90), gPlaneModal.format(17), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), "R" + rFormat.format(r), getFeed(feed));
break;
case PLANE_ZX:
writeBlock(gAbsIncModal.format(useIncremental ? 91 : 90), gPlaneModal.format(18), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), "R" + rFormat.format(r), getFeed(feed));
break;
case PLANE_YZ:
writeBlock(gAbsIncModal.format(useIncremental ? 91 : 90), gPlaneModal.format(19), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), "R" + rFormat.format(r), getFeed(feed));
break;
default:
} else {
var currentCoolantMode = COOLANT_OFF;
function setCoolant(coolant) {
if (isProbeOperation()) { // avoid coolant output for probing
coolant = COOLANT_OFF;
if (coolant == currentCoolantMode) {
return; // coolant is already active
if (coolant == COOLANT_OFF) {
writeBlock(mFormat.format((currentCoolantMode == COOLANT_THROUGH_TOOL) ? 89 : 9));
return;
var m;
switch (coolant) {
case COOLANT_FLOOD:
m = 8;
break;
case COOLANT_THROUGH_TOOL:
m = 88;
break;
default:
onUnsupportedCoolant(coolant);
m = 9;
if (m) {
writeBlock(mFormat.format(m));
currentCoolantMode = coolant;
var mapCommand = {
COMMAND_STOP:0,
COMMAND_OPTIONAL_STOP:1,
COMMAND_END:2,
COMMAND_SPINDLE_CLOCKWISE:3,
COMMAND_SPINDLE_COUNTERCLOCKWISE:4,
COMMAND_STOP_SPINDLE:5,
COMMAND_ORIENTATE_SPINDLE:19
function onCommand(command) {
switch (command) {
case COMMAND_COOLANT_OFF:
setCoolant(COOLANT_OFF);
return;
case COMMAND_COOLANT_ON:
setCoolant(COOLANT_FLOOD);
return;
case COMMAND_STOP:
writeBlock(mFormat.format(0));
forceSpindleSpeed = true;
return;
case COMMAND_START_SPINDLE:
onCommand(tool.clockwise ? COMMAND_SPINDLE_CLOCKWISE : COMMAND_SPINDLE_COUNTERCLOCKWISE);
return;
case COMMAND_LOCK_MULTI_AXIS:
return;
case COMMAND_UNLOCK_MULTI_AXIS:
return;
case COMMAND_START_CHIP_TRANSPORT:
return;
case COMMAND_STOP_CHIP_TRANSPORT:
return;
case COMMAND_BREAK_CONTROL:
return;
case COMMAND_TOOL_MEASURE:
return;
var stringId = getCommandStringId(command);
var mcode = mapCommand[stringId];
if (mcode != undefined) {
writeBlock(mFormat.format(mcode));
} else {
onUnsupportedCommand(command);
function onSectionEnd() {
if (((getCurrentSectionId() + 1) >= getNumberOfSections()) ||
(tool.number != getNextSection().getTool().number)) {
onCommand(COMMAND_BREAK_CONTROL);
forceAny();
/** Output block to do safe retract and/or move to home position. */
function writeRetract() {
if (arguments.length == 0) {
error(localize("No axis specified for writeRetract()."));
return;
var words = []; // store all retracted axes in an array
for (var i = 0; i < arguments.length; ++i) {
let instances = 0; // checks for duplicate retract calls
for (var j = 0; j < arguments.length; ++j) {
if (arguments[i] == arguments[j]) {
++instances;
if (instances > 1) { // error if there are multiple retract calls for the same axis
error(localize("Cannot retract the same axis twice in one line"));
return;
switch (arguments[i]) {
case X:
words.push("X" + xyzFormat.format(machineConfiguration.hasHomePositionX() ? machineConfiguration.getHomePositionX() : 0));
break;
case Y:
words.push("Y" + xyzFormat.format(machineConfiguration.hasHomePositionY() ? machineConfiguration.getHomePositionY() : 0));
break;
case Z:
writeBlock(gFormat.format(28), gAbsIncModal.format(91), "Z" + xyzFormat.format(machineConfiguration.getRetractPlane())); // retract
zOutput.reset();
retracted = true; // specifies that the tool has been retracted to the safe plane
break;
default:
error(localize("Bad axis specified for writeRetract()."));
return;
if (words.length > 0) {
if (!machineConfiguration.hasHomePositionX() && !machineConfiguration.hasHomePositionY()) {
writeBlock(gFormat.format(28), gAbsIncModal.format(91), words); // retract
if (!properties.useIncremental) {
} else {
writeBlock(gAbsIncModal.format(90), gFormat.format(53), gMotionModal.format(0), words); // retract
function onClose() {
writeln("");
retracted = true;
disableLengthCompensation(true);
zOutput.reset();
setWorkPlane(new Vector(0, 0, 0)); // reset working plane
if (properties.useG54x4) {
writeBlock(gFormat.format(54.4), "P0");
// 90/91 mode is don't care
writeBlock(gFormat.format(28), gAbsIncModal.format(91), "X" + xyzFormat.format(0), "Y" + xyzFormat.format(0)); // return to home
} else {
var homeX;
if (machineConfiguration.hasHomePositionX()) {
homeX = "X" + xyzFormat.format(machineConfiguration.getHomePositionX());
var homeY;
if (machineConfiguration.hasHomePositionY()) {
homeY = "Y" + xyzFormat.format(machineConfiguration.getHomePositionY());
writeBlock(gAbsIncModal.format(90), gFormat.format(53), gMotionModal.format(0), homeX, homeY);
onImpliedCommand(COMMAND_END);
onImpliedCommand(COMMAND_STOP_SPINDLE);
writeBlock(mFormat.format(30)); // stop program, spindle stop, coolant off
writeln("%");
