CAM Post
CAM Post
EmreYucel34
CAM Post
EmreYucel34
Hello, we are setting up 2 setups in Inventor CAM to perform upper surface operations and lower surface operations, when creating tool paths, can we create on 1 NC code or do we need to create NC code separately, our goal is to run 2 Setups in 1 NC code, our machine Fanuc
JDMather
@EmreYucel34
You have posted in the Inventor (design) forum, not the Inventor CAM forum.
AdamKunzo
Do you have 3 axis machine? Then you'll need 1 code to finish first side, flip your part and then start second code to finish the other side.
