Autodesk HSM Post Editor for Visual Studio Code goes live
fonsecr
Alumni Alumni
Message 1 of 136
fonsecr
Hi all post developers,
We just pushed Autodesk HSM Post Editor for Visual Studio Code live as an Open Source project under the MIT license. Check it out at:
https://github.com/Autodesk/cam-posteditor
This project is an extension for Visual Studio Code that makes life much easier when developing posts.
You can get the installation for Visual Studio Code at:
https://marketplace.visualstudio.com/items?itemName=Autodesk.hsm-post-processor
@GeorgeRoberts has been working on this until now. But my hope is that we can work together as a community to make it even better. So if you are interested in contributing make sure to engage. Of course you are welcome to just make requests for the post team also. You can use the post idea station for such requests.
Note that you need to sign a small agreement before we can accept contributions.See the README for details.
George will post introduction to the extension here.
René Fonseca
Software Architect
Replies (135)
Message 61 of 136
makko74
Hey @GeorgeRoberts
thanks for your reply and suggestion.
I had already tried that but somehow still no window was to be seen, I try it again on Monday.
Since I seem to be the only one with such special post-processors and I now know where to change it, it should not be necessary to insert it as a parameter. (But I would enjoy it anyway. Smiley Wink )
Thanks a lot and a nice weekend
Mario
InfoInventor CAM(Ultimate) user --- Inventor Professional 2021.2 + Inventor CAM Ultimate 8.1.2.21785
Message 62 of 136
makko74
Hello @GeorgeRoberts,
i've tried again but without success, the post.exe window does not want to be visible. Now I have a property in the postprocessor that suppresses the messages. At least that's the way it works.
Thank you for your help
Mario
Message 63 of 136
(sorry, had made reply to wrong post)
Message 64 of 136
hi
I have same issue as guys above.
Depend on a point I click a line in the processes NC file in right pane in VSC - it navigates to different code point in left pane. It looks like when more right side I click then more deep in call stack it shows.hsm_err1.jpg
May be it's such feature? 🙂
PS. At 2:45 of the intro video you click to bore.cnc file (in CNC SELECTOR pane) and then VSC showed the command bar on top of code pane. My VCS doesn't that so I have to run process manually from command bar. Maybe I had disabled something in VSC? How to enable it?
Message 65 of 136
makko74
@GeorgeRoberts
Unfortunately, it does not work to get the post.exe window visible. Maybe I have a wrong setting in vscode, I do not know.
But what helped was adding the parameter "--allowui" to the extension.js. So at least the message boxes are visible during the post process, that's all I need.
Mario
Message 66 of 136
fdboswell
Very cool VS Code extension, thanks. And another upvote for MAC support.
Message 67 of 136
AchimN
Hi all,
FYI, we have pushed an update for the HSM Post Editor Addin today which offers support for showing and modifying the post properties. This gives you the option to test your post with your properties without actually changing the property defaults into the post since it is easy to forget to change them back.
Let us know if you have issues with it.
Thanks, Achim
Achim.N
Principal Technology Consultant
Message 68 of 136
sharmstr
I cant seem to get the post to work.  Every time I try I get an error saying "Post processing failed, see log for details".  I have no idea what log its referring to, but I did find a renderer1.log file.  In there, there are errors about a file lock on /appdata/local/temp/debuggedfile.log.
I'm running Windows 10 and using the generic HAAS post. I've restarted my computer to "unlock" the file, but I still get the same error.
Message 69 of 136
CAMXPRESS
Hello All,
I have a problem when I like to run the postprocess inside VSCode. I have the following error:
- Running the contributed command:'HSM.postProcess' failed.
What I have:
- The latest VSCode : 1.32.3
- Installed ADSK HSM PP Extension: 2.1.1
- Linked the post.exe what is the plugin directory (getting from Fusion directory, mozjs.dll also)
The other functionality of the plugin works well : Function list etc.
What is worng with my installation?
Any help would welcome.
Joe
Message 70 of 136
AchimN
Please update the extension, the latest version is 2.3.4
Achim.N
Message 71 of 136
CAMXPRESS
Thank you Achim, It is working now!
Joe
Message 72 of 136
Does this still not work on macOS? Just installed it in VSC and it doesn't work on Mojave.
Message 73 of 136
Hello !
I have the same problem ... the extension does not work for VSCode in MacOS ... are you planning a version for Mac users?
Thank you !
Message 74 of 136
daniel_lyall
@GeorgeRoberts  a nudge How's the Mac version going I so want it.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 75 of 136
GeorgeRoberts
@daniel_lyall I've now added support for MAC. You should be able to get it from the extension store
It's tricky finding the post executable (in the fusion install location), need to find a good way of doing that... Hopefully I can get something this week
George Roberts
Manufacturing Product manager
If you'd like to provide feedback and discuss how you would like things to be in the future, Email Me and we can arrange a virtual meeting!
Message 76 of 136
daniel_lyall
Thank you
Daniel Lyall
The Big Boss
Mach3 User
Message 77 of 136
Hi George, I've already tried it and it works!
In my case, the executable of my post processor is in this path :
"/Users/youruser/Library/Application Support/Autodesk/webdeploy/production/randomcodelikethisaaf284e803ac0029ad088753e/Libraries/Applications/CAM360/"
The best way I had to get to this file has been with the following steps:
- control + click on the Fusion360 icon to show the options ..
- then go to options
- view in finder (finder opens)
- then navigate to .. Libraries - Applications - CAM360
- there is the "post" file
- control + click in "post" file and press option key to copy "post" as path
- in VSCode go to .. HSM: Change Post Executable - Browse
- press shift + command + G and paste you path ..
- select "post" file, and click open ..
- ready it will be working ! ..
Thanks again George ..
Message 78 of 136
bozboyle
Hi everything appears to be ok. I can choose my custom cnc file and my .cps post and my post .exe. But when I do a CTRL ALT G it says
  Running the contributed command: 'HSM.postProcess'failed.
and nothing happens
regards Boz
Message 79 of 136
GeorgeRoberts
Thanks for posting. That error usually means something in the extension has failed to start...
Do you have a .cps file open? If so, are the functions / CNC files shown in the explorer sidebar?
George Roberts
Message 80 of 136
CAMXPRESS
Hello George,
Do we have any method to post Machine Kinematic information to the VSCode export file and use it
directly at VSCode?  How we could easily handle the Machine Kinematic related parameters at VSCode?
Joe
