HSM Post Processor Forum
Adding Cutting Time for every tool to the header
1 REPLY 1
j_zander
178 Views, 1 Reply
Hey Guys,
we  are going to get a new machine with a robot. The robots software has a toolmanagementsystem. To use this i have to post the cuttingtime of every tool to the Nc-prgram header like this:
With the DeferredVariables Propery/Function  from the postprocessor training guide i was able to add the time in seconds to the post. But now i'm struggeling to change it to the right format. I wanted to use this function to change the cutting times format:
function convertToTimeFormat(totaltoolTime){
    var format = "HH:MM:SS".split(":")[0];
    var hours, minutes, result, seconds;
    if (format == "HH" || format == "MM") {
      hours = Math.floor(totaltoolTime / 3600);
      totaltoolTime -= (format == "HH") ? hours * 3600 : 0;
      minutes = Math.floor(totaltoolTime / 60);
      totaltoolTime -= minutes * 60;
    seconds = totaltoolTime.toFixed(1);
    if (format == "HH") {
      result = hours + "Hrs " + minutes + "Min " + seconds + "Sec";
    } else if (format == "MM") {
      result = minutes + "Min " + seconds + "Sec";
    } else {
      result = seconds + "Sec";
    return result;
It seems like the DeferredVariable is not a number.
Intstead of the new values i only get NaN.
I hope somebody can help.
Attached you can find my post I am playing with.
Tags (3)
1 REPLY 1
serge.quiblier
in reply to: j_zander
Hi @j_zander
In the dditive posts, we are using something like :
function formatCycleTime(cycleTime) {
  var seconds = cycleTime % 60 | 0;
  var minutes = ((cycleTime - seconds) / 60 | 0) % 60;
  var hours = (cycleTime - minutes * 60 - seconds) / (60 * 60) | 0;
  if (hours > 0) {
    return subst(localize("%1h:%2m:%3s"), hours, minutes, seconds);
  } else if (minutes > 0) {
    return subst(localize("%1m:%2s"), minutes, seconds);
  } else {
    return subst(localize("%1s"), seconds);
You can build your own code from this sample. If you don't have to translate H, M S just remove the localize function call, and just keep the string.
Regards
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
Technology Administrators
