808D Siemens Post Processor giving me an error
b00075868
b00075868
I am trying to use the 808D siemens post processor (Provided by the fusion360 library) to see if the G code generated will work on my machine but I am receiving an error whenever I try to post it,
I tried to use the Siemens turning post processor (Also provided by the fusion360 library) and it works just fine but my machine is unable to read that g code as it is programmed to read 808D post processors, is there any way to fix this issue or is there something I need to do before hand to make sure it works?
The error obtained is shown below:
Information: Configuration: Siemens SINUMERIK 808D
Information: Vendor: Siemens
Information: Posting intermediate data to 'C:\Users\Design\Documents\Fusion 360\NC Programs\1001.mpf'
Error: Failed to post process. See below for details.
Code page changed to '1252 (ANSI - Latin I)'
Start time: Saturday, July 29, 2023 2:46:18 PM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.5971.0
Configuration path: C:/Users/Design/AppData/Roaming/Autodesk/Fusion 360 CAM/Posts/siemens-808d.cps
Security level: 1000
Include paths: C:/Users/Design/AppData/Roaming/Autodesk/Fusion 360 CAM/Posts
Configuration modification date: Thursday, July 27, 2023 12:41:22 PM
Output path: C:\Users\Design\Documents\Fusion 360\NC Programs\1001.mpf
Checksum of intermediate NC data: ab6c39489b9db8fe84c2650c37eefd49
Checksum of configuration: 6507de86ed2d155a160d0160f1664083
Vendor url: http://www.siemens.com
Legal: Copyright (C) 2012-2023 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.16753
Error: Turning toolpath is not supported by the post configuration.
Failed while processing onOpen().
Error:
Error: Failed to invoke 'onOpen' in the post configuration.
Error: Failed to execute configuration.
Stop time: Saturday, August 8, 2023 2:46:18 PM
Post processing failed.
CNC_Lee
@b00075868
You will need to get a custom post processor written if the generic posts are not providing the required output for your machine. I offer post processor development services and happy to work out a solution for your machine! PM me if still needing assistance.
If my post answers your question, please use Accept as Solution.
CNC Lee
Autodesk CAM Post Processor Expert
