Hi, I have recently acquired new CMS 5 axis Athena 3015. I am trying out the osai post processor downloaded from the HSM database. I have ( I think )made the modes to the post config to enable and configure the post but it isn't coming out right. I have attached the modified cps file and 2 posts. 1 with TCP enabled ( optimizeMachineAngles2(0); // TCP mode) and one without ( optimizeMachineAngles2(1); // TCP mode) Both posts are the same. Should the not be different?
Should the post with TCP enabled not be a simpler post because the tip of the tool goes around on the same z height?
The file is just a tryout file of a swarf chamfer around the top of a rectangle, I will post a screenshot of it next and a screenshot of the backplot. I'm not even sure if the backplot means anything.
Thank you in advance,
George Comber
Here are the screenshots of the toolpath and the backplots.
When I turn on the TCP I get the same post and when I put in a machine config in solidworks, I get the same post as when I put in undefined machine?
Do the machine configuration settings in the HSMworks menu override the settings in the post config or vice versa?
Regards and thanks again,
George
Hello @Anonymous ,
we are working on Belotti Osai post processor. Usually Belotti machines have similar kinematics to CMS ones.
Maybe it could be useful to satisfy your request.
If so, you can find the first version of the Belotti Osai post postprocessor in the hidden area.
Feel free to download it:
https://cam.autodesk.com/hsmposts?p=belotti_osai
Please test it carefully and let me know. It is still under development.
I need 5 axis CMS OSAI TCP Post for Autodesk PowerMill & Someone please guide me which post will compatible with PowerMill Software to run CMS OSAI Machine.
Hi, I purchased Belotti Osai FLA 4018. I have problems configuring the kinematics in Solidworks, could you help me. Thanks
@c_caserta71 @reliable_solutions
If the generic posts are not providing the required output, I offer post processor development services and happy to work out a solution for your machine! Please message me if still needing assistance.
