Good morning,
would like to prevent the post processor to need data entry of the B angle every time, for each activity, in case the value of this angle remains always the same for each activity. Is it possible?
Thank you
Best regards
Are you using default post processor or modified one? Because in default there should be a condition that angle is called on if (newWorkPlane) is true.
You can send me a message if you need a help, I'll take a look at it for you.
So this is a sample code from your post processor. I used same tool and same workplane.
The rotation is there only for the first operation, it's not duplicated for the second operation.
Did I misunderstand your question or do you get a different output?
Good job @AdamKunzo !
This is precisely what I was inquiring about. An excellent solution.
Can you tell me the modification to be made on the post processor?
Best regards
I didn't make any post processor modification, I just update machine simulation with your post processor (it was link to different post processor name).
Thank you,
Can I ask you how to update the machine simulation? I've uploaded the machine to the library. I've loaded the post processor into the machine, but I can't update the simulation. Could you help me?
Best regards
