- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
After having spend multiple days and hours editing this Post Processor for a Danibrum 5 axis machine (Head/Head) using a Syntec controller, i got stuck. My limits are A(130/-130) and C(360/-360). Talking to the Machinebuilder they advised me to use only ABC moves for 3+2 Positioning.
I tried activating the ABC Prepositioning, but this seemed to not have any effect.
Doing 5 axis machining works perfectly fine and simulates it nicely(in Fusion)
Doing 3+2 Axis machining works fine also IF: it is only 1 operation in 1 program. (Simulation is complelety wrong side).
The machine has RTCP and can read G68.2 and G53.1.
If there are multiple 3+2 operations it seems to add the Coordinates, even if a G49 is used. Resulting in a software limit exceed error.
Here is an example:
O1001
(MACHINE)
( VENDOR DANIBRUM)
( MODEL BCM2130)
( DESCRIPTION 5 AXIS HEAD HEAD)
(T2 D=11.8 CR=0. - FLAT END MILL)
N10 G00 G53 Z0.
N15 G00 G91 G28 A0. C0.
N20 G90
(2D ADAPTIVE1)
N25 M06 T2
N30 M03 S18000
N35 G17 G90 G94
N40 G54
N45 G00 G53 Z0.
N50 G68.2 X0. Y0. Z0. I90. J90. K0.
N55 G53.1
N60 G43.4 H02 G54 Z172.5
N65 G90 G00 G54 X35.682 Y-38.329
N70 G00 Z162.5
N75 Z148.68
N80 G01 Z147.5 F6000.
N85 Z145.5
N90 G03 X29.455 Y-36.5 I-6.683 J-11.241
N4140 X22.979 Y-7.074 Z138.18
N4145 G00 Z172.5
N4150 G49
N4155 G00 G53 Z0.
N4160 G90 //works fine until here
(SLOT1)
N4165 G69
N4170 G68.2 X0. Y0. Z0. I-90. J90. K0.
N4175 G53.1 //Here i get an error that it's exceeding my software limits
N4180 G43.4 H02 G54 Z172.5
N4185 G00 G54 X-9. Y-18.25
N4190 G00 Z162.5
N4195 G01 Z160. F6000.
N4260 G00 Z172.5
N4265 G49
N4270 G00 G53 Z0.
N4275 G90
(2D POCKET2)
N4280 G69
N4285 G68.2 X0. Y0. Z0. I0. J90. K0.
N4290 G53.1 //Here again i get an error message
N4295 G43.4 H02 G54 Z38.5
N4300 G00 G54 X-117.652 Y-17.65
N4305 G00 Z28.5
N4425 G00 Z38.5
N4430 G17
N4435 M05
N4440 G49
N4445 G00 G53 Z0.
N4450 G90
N4455 G69
N4460 M30
If i execute each one in sepparate Programs, they all work fine.
Thank you for your time, honestly much appreciated.
If you can guide me in the right direction, i'm honestly stuck here.
