I have submitted this before but want to add to the idea station to gather support.
When Drilling in square tubing, if you select two or more holes concentric to each other on the top and bottom layer of the tubing, it continues to feed in between both layers wasting a lot of time. it would awesome if the software would recognize there are two different holes (meaning it has two different hole tops and hole bottoms) and rapid in between them. It should only feed in between the holes if merge hole segments is checked.
