Stock Simulation Events window
Stock Simulation Events window-
I have to close that window one more time... I will lose my mind!  😉
Please make it optional for the window to open only if there is a problem with the rendering, instead of every time you run the rendering... for no reason.
3 Comments
You know you don't have to close it right?
It only pops-up at errors and at the end.
If you close the simulation it will close too.
You can also resize/reposition it and it should stay like that.
In HSMworks you can also right click and select show log to hide it from the get go if you'd like
That is an ok option, but it is nice to have a window pop up when something is wrong.  That way you aren't used to ignoring the window that pops up every single time.  This works well on other software.  It is an option called "log to display" for collisions.  No collisions... no window.
Thanks for the input everyone.
