Save toolpath into cloud, so no need to regenerate while opening new file
Hi all,
I am using Fusion 360 , I have a suggestion for Fusion360 Cam part.
When i open an old file which has model as well as CAM processes. Then i have to regenerate the toolpath if i want to post the G Code.
So My idea is to save toolpath files also so if i save a part in fusion 360, it has to save CAM processes also that are previously generated.
So no need to regenerate the G Code for previously saved process.
Thank You
AMIT KUMAR
1 Comment
kb9ydn
You can mostly accomplish this already.  Once you have your tool paths finalized you can protect them (right click on tool path and enable protect) to make them read only.  They will be locked from editing and will never be marked as needing regeneration, forever until you unprotect them.  You would still need to post them again the next time but that takes no time at all compared to regeneration.
C|
