I have a turret on my Tormach lathe and I also have a QC post below that cuts from -X. Fusion 360 has no way of working in the -X area. The spindle turns the same direction (CCW) the tool just needs to cut in the +X direction instead of the -X direction.
I mounted a boring bar in my QC post and Fusion won't even output a useful tool path that I could go and manually (unfortunately) change all the X values. Why is there not already support for this? Tolls in the QC that cut on X0 (drills, taps, etc) work fine. But If I want to put a specialty cutter on the QC that I don't wan tin the turret all the time I can't do it.
I found someone's workaround post processor that will change X values based on tool number and turret number but I can't get it to work and if F360 won't make a correct toolpath for the part then simply swapping X values won't do any good.
