OK here is the scenario. You have a HOT job that you want to post across various machines with different max spindle limits. (My current CAM programming problem.) My work around is to copy the job and manually adjust each tool to not exceed the machines max spindle speed. Not a big deal if you only have a few tools. But do it for 20 tools and 3 different machines and tell me how you like managing that mess.
With the current product you have to edit each tool with regards to spindle speed limits to get optimum output from the machines. If the system would allow for the machine configuration to over ride the speed / feed based on a max SFM setting relative to each tool. Then the task of posting to various machines with different spindle max limits becomes a non issue.
Thoughts anyone? I tend to overreach allot with CAM packages. It's my nature to exploit the system to the max.
