Option to output different WCS with each Pattern instance.
Unless my multi part fixture is dead exact with the same spacing as my model I'll output a different work offset for each pattern instance. Especially when probing each instance.
Right now I have to create a different setup folder to override the WCS and duplicate the operation. By doing this I have 2 or more separate operations that I have to update independently when I need them to be the same.
Also if indexing the WCS for each Pattern instance was available I could take advantage of the Operation order options.
This option would ideally be placed under the Post Process tab with creating a Pattern.
I know this has been brought in the form in different situations but I didn't see in represented in the Ideas form.
