Since HSMworks 2016 version 2.405 the way lead ins and lead outs are created has been different. Now, if a larger safe distance is specified there is a long linear lead in/out attached to the specified radius. The sweep angle also doesn't seem to do anything when it's value is changed. There is a photo attached. The long linear lead in/out is an issue when you rough out a pocket defined by a smaller boundary. If you go back in there to finish using a 3d contour strategy the long lead in may plunge into stock that hasn't been removed yet.
