It would be great to have the ability to offset the face milling operation, EG. using an 80mm face cutter to face 60mm plate, so HSM generates a single tool path on center-line of the part, this was no good for the material or cutter i was machining so I had to manually edit the G-code to offset the Y value, being able to do this is HSM would be much better.
