Pocket not generating rectangular shape
Hi everyone,
Would appreciate some help in generating the correct toolpath for a rectangular shape. I tried a 2d pocket and the shape is an oval rather than the rectangle of the model. I have attached the part file for reference.
Cheers!
Andy.
Laurens-3DTechDraw
HI Andy,
Do you mean the radius in the corners?
Well, this is one of the limits of milling, you "can't" get a sharp inside corner.
The smaller tool you pick, the smaller the radius will be.
You would have to would have to make some dogbone fillets to make a square piece fit in or make it in another way.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
lenny_1962
When I have things like this this is what I do.
if this doesn't work for you then as Laurens said you'll need to use smaller tools and then take a file and square out.
or you can drill the a hole on each of the corners, would have to be fairly small do to not much material.
