Machining an Augur Helix/Flighting
Steinwerks
Mentor Mentor
Message 1 of 10
Steinwerks
Having a lot of issues trying to get this working:
image.pngCan't share the file publicly.
@Rob_Lockwood this is your wheelhouse I think...
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Replies (9)
Message 2 of 10
Search for this (Possibility of simultaneous 5-axis CAM on threaded part?) in the support forum, it might help.
Jason
Message 3 of 10
Steinwerks
After much trial and error I've gotten it working. I'm stuck on a 4th axis machine so that compounds issues of course. Much of it is bad geometry and working around fillets that don't actually need to be there (thanks engineer!).
Neal Stein
Find me on:
Message 4 of 10
lenny_1962
Is this HSMWorks? I had a auger like this a year ago, used 3D Adaptive to ruff and finish it, worked like a dream. Showed it on the forum some time around April\May 2017
Message 5 of 10
Steinwerks
I've done so little 4th axis work that I forget there is axis substitution. I'll see if I can find your post. Swarf using 4th axis actually worked pretty well. I did have to simplify the geometry though (suppressing fillets for instance).
Neal Stein
Find me on:
Message 6 of 10
ArjanDijk
Did you try Flow? I had nice results in Inventor HSM with 4 axis limit
Inventor HSM and Fusion 360 CAM trainer and postprocessor builder in the Netherlands and Belgium.
Message 7 of 10
Steinwerks
I did, with some results on the radius, except the radius is the least important part. I am trying some things on a test model at home today off and on so I will give it another shot and see what I can come up with.
Neal Stein
Find me on:
Message 8 of 10
ArjanDijk
My model was completely round, so no flat walls, so no option to use Swarf, I can imagine that your i different
Message 9 of 10
Good thing to do.
Message 10 of 10
lenny_1962
Stien,
here's some pics of the auger using only 3D Adaptive.
1 inch bullnose with a .25 rad.
could not do swarf because blade profile is a radius.
