Inventor CAM - Follow a 3D fillet with a ball nose?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
This is not my IP, so I really shouldn't post the part. I've cut this part with a 12mm ball nose using the 3D contouring strategy. It came out fine, but the filleted areas could be better. This seems to be due to the nature of the "top down" section by section nature of the 3D contouring strategy.
I've messed around quite a bit and is there not a simple way for me to just force the bottom center of the tool to follow the selected lines? FYI, the fillets in the model are R6, so everything should match up quite nicely.
The parallel strategy (second pic below) seems to come close, but it's still just basically moving the section-by-section work from a vertical strategy to a horizontal one. There's got to be a simpler way to slick up the corners. Suggestions?
