HSM not Posting cutter comp G41 haas
JamesCipolloni7683
JamesCipolloni7683
For some reason the haas post is no longer adding cutter comp in the post, what would cause this ?
Jim
What software are you using?
Are you using the same post?
Do you have cutter comp turned on in cam?
Jason
JamesCipolloni7683
2018 Inventor HMS Express
 $Revision: 41655 94a1d5d2a049ff5f998f7563580a7f54645b44b4 $
  $Date: 2017-10-18 23:59:13 $
Where do you turn cutter comp on?
JamesCipolloni7683
Looking further into this I see I was using the wrong setting , I set to wear and it gave the cutter comp I'm looking for, off an control seem to give the same output , I myself have never seen a shop program without 1/2 the tool dia except when you want to cut right down the center of geometry. maybe there are other reasons
Jim
ArjanDijk
Cutter comp is more prone to error because every radius needs to fit. Its really convenient to use when programming on the machine, but in HSM you basically only use it for a wall finish that need accuracy. HSM compensates it for you if you don't use "in control"
Inventor HSM and Fusion 360 CAM trainer and postprocessor builder in the Netherlands and Belgium.
