HSM Bug
HSM Bug
Message 1 of 11
HSM Bug
Good morning all i had a customer ring me with a bug in Inventor and was wondering if anyone was experiencing the same bug! (see Picture) I am able to replicate in Inventor 2017/2018 with HSM 2018.
Replies (10)
Message 2 of 11
Just to add when you change the Bottom selection to "selection" it has referenced the surface selected in the Bottom Reference.
Message 3 of 11
jeff.pek
Hmmm. That certainly looks bad.
We'll take a look.
Thanks for the report.
Jeff
Message 4 of 11
Thanks Jeff my thoughts exactly.
Message 5 of 11
jeff.pek
Hi again -
I took a closer look at this, and think I know what's happening.
When you choose "Selection" from the top height dropdown, the "Top reference" selection button should be activated. But that's not happening, so the Bottom Height selection button, which was enabled behind the scenes gets the selection.
If you explicitly click the Top reference arrow button, which should turn it blue, then you'll be able to have your selection applied to the right place.
I'll get this defect reported. Meanwhile, hopefully this workaround will get you going.
Jeff
Message 6 of 11
Ahhhh brilliant will pass on the information and hope to see it in the next hot-fix 😛 Cheers for the speedy response Jeff.
Sean
Message 7 of 11
narzinskin
This is irritating and it has been like this for quite a while.
Message 8 of 11
Bartlett-Pentagon
I've had the same thing happening. I just have to keep re selecting a few times to get it to work.
Message 9 of 11
rgollob
I agree this has been an issue for a long time and is very annoying. I hope this will be fixed now! Its not just the top reference. Its every one of them when you change to "Selection" from the drop down it doesn't automatically select the arrow. It defaults to the bottom selection. I get frustrated with it daily.
Message 10 of 11
jeff.pek
Hi folks -
This was noted, about a year ago, as CAM-3614. We made an attempt to fix this a short while back, but ran into other issues, so rolled the fix back.
I'm digging into this again, and would love to see us able to make this work as (reasonably) expected, but we need to be careful of other impacts.
Jeff
Message 11 of 11
Thanks for the update Jeff. Let us know if you have any good news!
