Horizontal cant remember machining boundary between adjustments/regeneration
Bartlett-Pentagon
Bartlett-Pentagon
I select a machining boundary for horizontal, Generate tool path and everything is fine. I edit operation to adjust (stock to leave etc.), and it fails to generate tool path. I go back to edit, and the original boundary I selected is incorrect. I have to clear the boundary definition and re-select the correct boundary. Then it regenerated fine, but I have  to re-select any time i make and edit to the operation. Note, this boundary is from a sketch.
Laurens-3DTechDraw
Best way to report this is to make a video(See Autodesk Screencast) and send in feedback.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
Bartlett-Pentagon
Thanks Laurens. Created a screencast and uploaded. I'm assuming it went to support.
Bartlett-Pentagon
Bartlett-Pentagon
Welcome Steven Shaw !
