Backwards boring bar setup for lathe
CAD_CAM_MAN
CAD_CAM_MAN
How should I go about setting up a backwards boring bar in the tool library for ID back boring? There does not seem to be an option for this type of tool (see pic). What am I missing?
I would like to be able to accurately see potential collisions with the end of the tool and internal features or fixturing.
Marco.Takx
Hi @CAD_CAM_MAN,
At the moment within Inventor Not possible, only if you set it up without holder.
Within Fusion 360 you have a little bit more control for your holder, but it is even useless in your case.
Don't create a larger Leading Angle than 54,9 because you end up with this 😂
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
ajfriessen
BUMP!!! Has there been any improvements with this?  I just ordered one of this boring bars......
