Solved by jeff.pek. Go to Solution.
Which directory are you referring to, exactly?
You probably want to be using a separate library area for the posts you want to use. This would not be touched by any updates.
Jeff
We have a directory on the network with post processors and tool libarys.. so when i update them all the computers get the updates.. works great!
Even when multiple people using them it goes alright.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
This is what I've done as well, that way I know the post is always up to date with any changes I've made, and the tool library is always consistent. Plus these get backed up with the standard network backups as well so they won't be lost in case of any potential data corruption or loss issue.
