I downloaded the 5-3 dev build that would allow 2017 HSM Pro to be installed today and did so. I don't see probing now and would like to know what happened? It was there on the 4-29 build.
Solved by porsbym. Go to Solution.
Solved by jeff.walters. Go to Solution.
You need to right click on the setup the select New Operation. Then Probing will be at the bottom of the list.
First time I opened up this combination, noticed the same thing....no probing in the ribbon, just the right click menu. But second time I started up the software, Probing was listed in the Job section of the ribbon just under Manual NC.
Just as an aside, after viewing Al's initial video on probing, I tried it out, but wasn't getting the same results. Took a little while to realize he was using stock created as a separate solid, as opposed to stock frame created in CAM Stock setup.
Fred
"Just as an aside, after viewing Al's initial video on probing, I tried it out, but wasn't getting the same results. Took a little while to realize he was using stock created as a separate solid, as opposed to stock frame created in CAM Stock setup."
I did not see the video and that explains why I could not probe my stock block today which is after all the first use for probing in most shops along with tool measurements.
Question about the philosophy behind how things are done. Wouldn't it make more sense to use the data collected in the creation of stock for probing rather than creating a whole new part and then bringing it in? If the CAM plan can see a solid there and derive an operation off of it why not probing to? This reminds me of the chamfer tool path which is quite often worthless if you want to use an exact model with chamfers modeled in and I have gone back to 2D Contour because of this. Chamfer looks cool until you work with it a bit and then you realise you see the potential future but not todays working reality.
would be nicely to have a uniform ribbon
ribbon in a ipt-file
ribbon in a iam-file
/Mario
unfortunately not, I have tried it.
In the iam-file is no opportunity to add the probing to the user menu, in the ipt-file it works
the ribbon is hardcoded in the InventorHSMAddinImpl.dll
/Mario
We have seen some cases where the ribbon is not updated.
In that case, try reseting the ribbon
If that does not do the trick, then try deleting the ribbonstate files from %APPDATA%\Autodesk\Inventor HSM (typically C:\Users\USERNAME\AppData\Roaming\Autodesk\Inventor HSM), and restart Inventor.
/Mark
Mark - thanks for the hint that i can pimp my ribbons over the xml-files.
/Mario
Dave,
two quick things:
Hi Al,
I wondered about the stock block thing since it made sense to me it should work off of data already there. It will be good to see probing worked on this year. As it is right now I just do it on the machine control since setting G54 is the very first step. I would imagine this is still the way I will work and Probing for features cut is what I really look forward to.
One of the important things your new documentation/manual guy will bring to the table I hope is information. I am a literal kind of guy so I struggled with why was Chamfering not working when the chamfers were right there on the part in front of me. Chamfers should work with a Chamfering tool path was my though and what was I doing wrong? A call to TP set me straight and since I am a firm believer in modeling parts just as they will be as a finished product I found the Chamfer tool path was not worthwhile at this time except for down and dirty quick corner treatment without leaving the CAM plan if the part needed chamfers. Documentation would have been nice to let me know this was a hint of things to come and not usable in many cases. I know things are in the works but without proper documentation I think it is better to just not put unfinished things out there until they can walk on their own or have clearly explained what the limitations and problems are..
