Mikkel wrote: |
I'm developing the morphed spiral strategy. I would appreciate all kinds of feed-back. The feature is very new, so it might easily happen that somebody discovers something that I have not seen so far. If you have any comments, please write.
Kind regards, Mikkel
Cool concept--
Take a look at the attached part-
It contains two duplicate operations, where the only difference is a slight change in stepover; however with very different results.
My assumption is, that this is where the normal pocket routine loses its ability to generate offset passes.
In practice, this algorithm almost seems like the worst of both worlds. It generates a very large program size, that doesnt have equal tool engagement, and appears to have a significantly longer runtime in virtually every scenario I tested.
Am I missing the upside? I realize the tool will remain in contact with the workpiece all the time, but I fail to see any real benefit from that.
I havent actually posted any code, so I cant attest to any performance effects.
