I'm currently working on blend, and I would love to get feedback from everybody who has tested it.
As I understand it, it is currently inconsistent, and basically failing on too many examples. It would be really great if you could post any failing examples you have in this thread, or send them to me directly, so we can make sure that we fix the issues.
It would also be good if you could post examples of where it gives a bad result, and an explanation of what you would want instead in those cases, or cases where you think it gives a good result, that we should try to get in more places.
Björn Johnsson
Sr. Software Engineer for HSM CAM
Solved by michael_taffertshofer. Go to Solution.
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
I only have 3 years till I retire so I have come to the realization that HSMWorks is at its finished matured state and I will use it until my last day or when they no longer give the option to use it, if that happens back to surfcam.
FWIW the other machinist in the shop use Fusion.
