Inventor HSM 2019.2 development release is now available at:
https://cam.autodesk.com/download/inventor-hsm-experimental
Please let us know if there are any issues. Thanks.
Noah
None of the hotkey/Shortkey's seem to work.
Tried Ctrl+G, Ctrl+D, Ctrl+L
Ctrl+S does seem to work.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Not sure what to say. These all work fine for me. You first selected a browser item, right?
Jeff
i'm not sure how this is possible, but it appears to be skipping the second writeBlock of all probing cases from my post. this was working yesterday. i tried rolling back versions and it is still having the same issue. any ideas?
Cannot reproduce this issue, it works fine on my end. Maybe you can share your part + post?
It ended up not being the post but the probing operations generated in this development release. I reverted back to the current release and had to recreate the probing opps..regenerating still produced the issue. I will share the assembly with the bad probe opps through send feedback.
thanks, Nick
I should have mentioned, regenerating the probe opps in the current release fixed the simulation issue, but they still won't post correctly. I tried my posts as well as the generic haas and fanuc with same results.
