When I select one volume body in the assembly then stock material for all volume bodies are created.
In the former releases one stockmaterial for all volumes where created and thats what we need.
SolidWorks 2019 x64 SP5.0, HSMWorks 2020 R3.43705 one body as model selected
SolidWorks 2019 x64 SP5.0, HSMWorks 2020 R3.43705 both bodies as model selected
SolidWorks 2019 x64 SP5.0, HSMWorks 2021 R0.43758 one body as model selected
SolidWorks 2019 x64 SP5.0, HSMWorks 2021 R0.43758 both bodies as model selected
Solved by jeff.pek. Go to Solution.
Hi Jeff,
it seems to be a random phenomenon though because when I open the file parallel to other assemblies the problem disapears sometimes.
Here is the model and also a clip.
Hi Michael -
Thanks for the model. I find that the issue seems to only be affecting the display of the stock graphics, while the stock itself seems to be correct, if you create an operation. We'll see if we can figure out why the display is off.
Jeff
