HSMWorks 2018 R3.42665
SolidWorks 2017 x64 SP4.1
Form Mill does not import file.
Import of SWX2016 File works. Import of SWX2017SP4.1 file does not work.
Solved by michael_taffertshofer. Go to Solution.
I attached two files. One worked and after saving it as new version (SWX) it did not work any more.
The other one (Horn 606.5519.02) is an old version and works. If you safe it in SWX2017SP4.1 it does not work any more at least in my situation.
Regs Michael
Hmm. I'm using SWX 2017 SP3.0, and had no problem importing either of these parts. Will try to do an update to a later SWX.
Jeff
Hi Jeff,
I have updated to SP5 and now it works fine.
THX for your participation
regs Michael
