Helius PFA Forum (Read-Only)
Welcome to Autodesk’s Helius PFA Forums. Share your knowledge, ask questions, and explore popular Helius PFA topics.
SVAR data not available
2 REPLIES 2
dean.rose
1234 Views, 2 Replies
I have some problems at applying MCT in Ansys 14.5. I made the model in Ansys Composit Prepost and transfered to Ansys Classic where I tried to use Helius MCT (Autodesk SCA) but the end of the process I got this message: "The requested SVAR data is not available. The PLESOL command is ignored".
Dean Rose
Tags (1)
Labels (3)
2 REPLIES 2
dean.rose
in reply to: dean.rose
I would suggest reading through the documentation in the Ansys tutorials for requesting output. You can define out as in the following exampe for SVAR. In order to view the fiber and matrix failure states generated by Simulation Composite Analysis, the user must request that the state variables (SVAR) be written in the ANSYS results (.rst) file.
Enter
OUTRES, SVAR, ALL
in the command prompt. This command specifies that all state variables are to be written to the results file at every substep.
Plotting
To plot SVAR1 using a PLESOL contour plot, enter
PLESOL, SVAR, 1
into the command prompt. The default plot will plot the bottom section point of the bottom layer and the top section point of the top layer. Please see user's guide and tutorials for more information regarding the use of state variables.
Dean Rose
Thank you for guiding me here. I got the error message after "PLESOL, SVAR, 1", since I used the Tutorial 1. Actually, the structure I analyze is almost the same as in the Tutorial, except I built it in Ansys ACP an then transferred to Classic, because I would use Autodesk SCA for further projects which require ACP. The materials were different so after invoking Autodesk I set the "9024" material ID for each material. Only the elements remained different, the tutorial uses Solid-shell, and I use Shell. This is what I can't modify in Classic. I uploaded my case here: Cubby. You may want to see.
Best regards,
Peter
