Feature enhancement for Export Material Utilty.
Enhancement of this feature, it would be useful if Autodesk Design had ability to specify temperature for lamina / laminate material coefficients.  Example: we use modulus at 5 or more temperatures for our simulations of engine components.
Currently, the user must create the laminate  for a given temperature, import into ANSYS, then manually give it a temperature.  Then, he has to do this for a second temperature of the same laminate, import, then cut and paste, add to the material card at the first material, and input the 2nd temperature value.
