3 (or 4) ports Video card...
cadman1965
cadman1965
I need to buy a new video card for my Win 7 AutoCAD Workstation and i need 3 monitors...
I was thinking about getting a NVIDIA Quadro NVS 440...
>> I was just told that  this isn't  a good choice by dgorsman!
Is that "compatible" with AutoCAD 2010 & 2011 ?
I'm searching here & there but cannot find something  that convinces me!
I'm open to suggestions & recommendations!
Merci beaucoup!
PS: dgorsman also told me 3 monitors could be bit excessive, but i really need 3
1 for my drawing
1 for my markups
1 for my spreadsheet or database...
(i did post this same message on a wrong area before: please excuse my redundancy)
cadman1965
Merci beaucoup!
dgorsman
I wouldn't recommend an NVS card, they aren't great for CAD applications.  Three monitors are a bit excessive, if you absolutely *must* have them, you're probably going to need twin dual-head cards.
Hardware discussions area: http://forums.autodesk.com/t5/Hardware/bd-p/116
cadman1965
thanks a lot mr dgorsman
I did repost my message there...
And yes: i need 3 monitors: i save a lot of paper  & time.
...and don't be shy to go there and gine me a new answer!  😉
cadman1965
BTW,
I'm only doing 2D...
There are few single cards that will drive 3 monitors... I'd look at a gtx680 - one card will support up to 4 monitors simultaneously. For 2d only uses that should provide more than enough power.
cadman1965
Thank you very much!
I will look at this closer... but as i just saw, it looks like a very good option.
Bonne  journée !
