character controller doesn't follow the translate terrain by scale
chlrh1226
Message 1 of 11
chlrh1226
hello,
i set up the character controller to entity on the keying scale animation terrain
like bellow attached .gif file.
character controller doesn't follow exactly the translate terrain by scale.
how can i set up the character controller exactly on the entity on the moving terrain?
Thanks in advance
Replies (10)
Message 2 of 11
nicolas_chaverou
Hey there,
Can you please specify which Golaem and Maya version you're using ?
Also some context: what are you using the CC for ? Is your sphere attached to a Crowd Rigid Body ? Does it scale properly ?
NICOLAS CHAVEROU
GOLAEM PRODUCT MANAGER
Message 3 of 11
chlrh1226
i use golaem version 9.0.2 and maya version 2024.
and i want to crawl up  each entity ( with character controller) on the moveing terrain( scale keying or deformed mesh)
but when i did a simple test(attached  gif flle), CC not follow exactly...
Message 4 of 11
chlrh1226
physics & terrain set up & terrain mesh scale keying
Message 5 of 11
chlrh1226
cc setup
entity setup
Message 6 of 11
nicolas_chaverou
I can not see any Rigid Body in your config:
https://help.autodesk.com/view/GOLM/ENU/?guid=glm_crowd-rigid-body
NICOLAS CHAVEROU
Message 7 of 11
chlrh1226
oh, sorry about that. i miss it.
i try with rigid body on sphere, still CC not follow that.
fix physics locator setting value. like that.
but still not follow the entity...
is this normal thing?
Message 8 of 11
nicolas_chaverou
Can you show what to does with the Crowd Rigid Body ?
I don't think crowd rigid bodies can change shape during a simulation
Do you think You can approximate your geometry with boxes and keyframe their transforms ?
NICOLAS CHAVEROU
Message 9 of 11
chlrh1226
Thank you for your reply.
first, i try to set up the character controller to entity on the keying scale animation terrain.
cc_error01(attached)
but i find out rigid body not follow the sphere mesh (&terrain )
even CC is not follow the entity.
https://forums.autodesk.com/t5/golaem-forum/cc-is-not-work-property/td-p/13660961
now this question is almost same upper question.
and now i got your last answer, i realize rigid body can't support scale keying animation & vertex keying animation.. right?
i thought rigid body support the scale keying animation & vertex keying animation..
because when i click the button "force refresh", it fit the mesh shape.
rigidBody_scale_01(attached)
rigidBody_deform_01(attached)
but you mean rigid body can't not support this both way. right?
rigid body only support translate & rotate keying animation. right?
Thanks, your help
Message 10 of 11
nicolas_chaverou
vertex animation is not supported by rigid body for sure - this is a limitation of the 3rd party engine we're using
I was not sure about scale so did a quick test but indeed it's not supported neither
Position / orientation are though
Studio usually sample / fracture their geometries in smaller pieces and use multiple rigid body in the case of vertex animation / scaling
Does that help ?
NICOLAS CHAVEROU
Message 11 of 11
chlrh1226
Thank you for your reply and time for me.
so, you mean vertex animation & scale not support with rigid body. right!?
my question is clear now! Thanks.
i try to use terrain using translate & orientation animation geometry.
Thank you so much!
