can i set up several geometry tag in mesh asset node?
chlrh1226
chlrh1226
hello!
can i set up several geometry tag in mesh asset node in same time?
if i have a lot of mesh node on geometry tap, i need to set up the geometry tag one by on..
could you let me know something to advise?
Thanks always!
nicolas_chaverou
Each Mesh can only be assigned with one Geometry Tag
What's the use case for requiring multiple tags ?
You can use the glmCharacterMaker command if you need to write a tag value to multiple meshes
https://help.autodesk.com/view/GOLM/ENU/?guid=glm_glmcharactermaker
Hope that helps
NICOLAS CHAVEROU
GOLAEM PRODUCT MANAGER
